Why is the IR-CUT OV5647 camera performing poorly?
I have attached images taken simultaneously in a dark room with the Arducam 5MP OV5647 Camera Module with Motorized IR-CUT Filter (SKU B003503) and the Sainsmart 5MP OV5647 Night Vision camera (SKU 101-40-237). The scene was being illuminated by the IR lights affixed to the Arducam camera, as well as an external IR light consisting of 12 LED beads in a circular array. Both cameras are operating with a Raspberry Pi 3B+.
The Arducam camera shows a dim, dark blue image, whereas the Sainsmart camera shows a clearer, pink image. Why the difference?
Hi @cwerner
Thank you for reaching out and providing the detailed comparison images and setup information.
The vast difference between the two images under identical lighting conditions is entirely due to the Motorized IR-CUT Filter present on the Arducam camera.
Here is exactly what is happening in your scene:
1. The Sainsmart Camera (Clear, Pink Image):
This camera is a dedicated “NoIR” (No IR filter) module. It does not have a physical glass filter blocking infrared light. Because of this, it successfully absorbs the light from both your attached IR LEDs and your external array. Digital sensors inherently see IR light, and the Raspberry Pi’s image signal processor translates this invisible infrared spectrum into a bright pink/purple hue.
2. The Arducam Camera (Dim, Dark Blue Image):
Your Arducam module is currently “stuck” in Daytime Mode, meaning its mechanical IR-CUT filter is currently engaged and covering the sensor . This glass filter is doing its job by actively blocking almost 100% of the infrared light you are shining at it.
Because the room is otherwise pitch-black and all your IR light is being blocked by the filter, the camera sensor is staring into total darkness. To compensate, it maxes out its internal gain (ISO), resulting in severe digital noise, and the auto-white balance fails, leaving you with that dim, deep blue artifact screen.
How to fix the Arducam:
The Arducam needs to trigger its mechanism to physically slide the IR-CUT filter out of the way for night capture.
  • Trigger the Light Sensor: Most of these modules switch to night mode automatically via a small photoresistor (light sensor) on the IR LED boards. Make sure there isn’t stray ambient light hitting this tiny sensor, which would cause the camera to think it is daytime.
  • Force Night Mode: If you are using this in a dedicated dark room, the easiest physical fix is to take a tiny piece of black electrical tape and cover the light sensor(s) completely. This will trick the board into thinking it is permanently nighttime, causing it to slide the IR filter away, and the Arducam image will instantly look just like the clear, pink Sainsmart image.
