Hi, I’m having trouble with the Arducam Cable Extension Kit for Raspberry Pi Camera (the up to 15-Meter Extension one). I’ve connected it to a Raspberry Pi HQ Camera on a Raspberry Pi 4, and it works fine for a few minutes and then the camera just stops working. I already swapped out the LAN/ethernet cable but the problem is still there. When I try to capture an image from Python it just hangs. I’ve tested this on two separate Raspberry Pi units and I get the same result on both. Can anyone help?
Hi, sorry to hear you’re running into this. Let’s try to narrow it down. A few questions so I can understand your setup better:
- What is the ethernet cable length you are using to work with the Raspberry Pi camera? This is important because the extension kit’s behavior can depend heavily on the cable length you’re running.
- Which Raspberry Pi OS / kernel version are you on, and are you using libcamera or the legacy stack?
In the meantime, you may find some useful references here:
- Arducam Forums: https://www.arducam.com/forums/
- Arducam documentation: https://www.arducam.com/documents/
If you can share the exact cable length and how you’ve got everything wired up, we can dig in from there.
Thanks for replying. The LAN cable I’m using is the same one that came with the module. The color is yellow. That’s the cable I’ve been testing with.
Thanks. That helps, but I still need the actual length of that yellow cable you’re using. The reason I keep coming back to it is that with these extension kits the run length is a big factor in the kind of symptom you’re describing (works briefly, then dies / capture hangs), so the number matters.
Can you measure or tell me the length of the cable that came with the module? Also:
Roughly how long does it run before the camera drops out?
What do you see when it fails — does
libcamera-still/ your Python capture just freeze, or do you get an error? -
Can you grab the kernel messages right after it fails? Something like:
dmesg | tail -n 50
vcgencmd get_camera
If it helps, please post the output here and we’ll continue from there.
I’ll try to get the cable length for you. On the failure side, it just freezes rather than throwing a clean error — the Python capture call never returns and I end up killing it. It’s the same on both Pi 4 boards I tried. I don’t have the dmesg output handy yet but I can pull it.
That matches what I’d expect for a signal/length issue rather than a software one, but let’s confirm before assuming anything.
When you get a chance, please run these and paste the results:
uname -a
cat /etc/os-release
vcgencmd get_camera
dmesg | tail -n 50
The OS/kernel version matters here too, so please include those. And still the key detail I need: the length of the yellow cable that came with the kit. Once I have both the length and the logs, I can point you in the right direction rather than guessing.
Ok here’s what I can give you for now:
- Board: Raspberry Pi 4
- Camera: Raspberry Pi HQ Camera
- Same result on two different Pi 4 units
- The cable is the yellow one that shipped with the extension kit
- Capture hangs (no clean error), usually after a few minutes of working fine
- Swapping the ethernet cable didn’t change anything
I still need to measure the exact cable length and run the dmesg commands you asked for. I’ll post those next.
Perfect, that’s a good start. To keep it moving, here’s where we are so far:
Current understanding:
- The camera works briefly, then drops out, and Python capture hangs (no clean error) — seen on two separate Pi 4 units.
- Swapping the cable didn’t resolve it, so it’s not just a single bad cable.
- The one open variable that still needs confirming is the actual cable length in your run, since the kit’s reliability is very dependent on it.
What I still need from you to proceed:
The exact length of the yellow cable (and whether it’s the full run or just part of it).
The output of:
uname -a
cat /etc/os-release
vcgencmd get_camera
dmesg | tail -n 50
Post those whenever you can and we’ll take the next step from there. There’s no confirmed fix yet on our side — this is still a diagnostic step, and the cable length is the piece we’re waiting on.
Understood. I’ll measure the cable and run those commands and post back here. Thanks for the help so far.
Sounds good. No rush — just reply in this thread with:
- The measured cable length
- The
uname -a/os-releaseoutput vcgencmd get_cameradmesg | tail -n 50captured right after the camera drops out
That’ll tell us whether this is a length/signal integrity problem or something else. Summary so far: intermittent camera dropout with hanging Python capture on two Pi 4 boards, cable swap didn’t help, and the open item is confirming the cable length plus the kernel logs. We’ll pick it up once you post those.
