Relevant wiki article: External Trigger Application - Arducam Wiki
Global shutter cameras like Omnivision OV7251, OV9281, OV2311 always have external trigger input signal called XVS . User can use a 3.3V trigger signal generated from Arduino, Raspberry pi or similar board to synchronize the capture process with hardware trigger event.
Conflicting Wiki Article: External Trigger Mode for Raspberry Pi Cameras - Arducam Wiki
The trigger interface described here requires a 1.8 V signal. Raspberry Pi GPIO outputs use 3.3 V logic. Use a suitable level shifter between the GPIO output and the camera trigger input; do not connect a 3.3 V or 5 V output directly to a 1.8 V input.
Relevant forum post: An error occurred: Sorry, new users can only put 2 links in a post.
.Good question, and yeah — the docs could be clearer on that point. The XVS trigger pin is actually dual-voltage compatible: it’ll happily work with either 1.8V or 3.3V signal levels. So you’re safe with 3.3V, which is convenient since that’s what you’d typically get from a Raspberry Pi GPIO or most common microcontrollers. The other trigger pins mentioned in the docs may be limited to 1.8V, but XVS is not — that’s part of what makes it the go-to pin for external trigger use
Conflicting forum post: An error occurred: Sorry, new users can only put 2 links in a post.
On the UC-788 Rev B, there’s no jumper or physical switch for XVS — the trigger signal is routed directly to the sensor once you enable it in software. So hardware-wise you should be fine as long as you’re feeding a clean 1.8V signal to the XVS pin.
Issue: It can’t both absolutely require 1.8V and also be compatible with 3.3V. Two One of the linked statements must be false.
Do I require a level shifter? I’d prefer not, as I am unable to find a 0ms-latency product. But I’d also prefer not to destroy my camera boards by feeding them incorrect voltage.
