What Camera Module am I actually using
    ArduCam
    No Idea
    Raspberry Pi 4
    OS: Raspbian GNU/Linux 11 (bullseye) aarch64
    Quick Start - Arducam Wiki
  5. Problems you were having?
    root@lager:/home/driver# libcamera-still
    Preview window unavailable
    [0:02:11.883945943] [1650] INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
    root@lager:/home/driver# vcgencmd get_camera
    supported=1 detected=0, libcamera interfaces=1
    root@lager:/home/driver# i2cdetect -y 10
    00: – – – – UU – – –
    60: – – – – – – – – – – – – 6c – – –
    70: – – – – – – – –
    root@lager:/home/driver# dmesg | grep imx
    [ 9.138221] imx519 10-001a: failed to read chip id 519, with error -5
    [ 9.139410] imx519: probe of 10-001a failed with error -5
    Follow multiple guides.
  8. What help do you need?
    I’m do not really know what this camara is expect that the camera module has “UC-721 Rev.D” written on the PCB. Thanks for the help in advance.
The Image above shows my current configuration and the camera itself.
Here are some more guides that I took in order do make it function myself but it did not work:
https://docs.arducam.com/Raspberry-Pi-Camera/Motorized-Focus-Camera/Quick-Start-Guide/OV5647-Motorized-Focus-Camera/
From extensive internet research I understood that the hardware of the U-721 adapter isn’t compatible with the Pi interface. (i2cdetect doesn’t provide an address - the Pi and the adapter aren’t able to talk to each other.) Nothing to do about that. Please, correct me if I am wrong (I have been struggeling for days and hours as well without success).
If I am correct, some clear communication from the Arducam team would be helpful and save us users from a lot of frustration. The questions I got from support didn’t touch the adapter version at all.
