When taking photos above 5-10m I get some shots which have wavy blurrly lines, otherwise the photos would be perfect. Its taken with a drone. Both when moving and when not moving
Troubleshooting attempts you’ve made? Tried different libcamera-still settings but can’t change it. Sett Exposure to 1us
Advice on what causes it, and troubleshooting tips. I have googled everywhere and nobody else seems to have the problem.
Hi @tank104
After checking the image you attached, I would like to know if this picture was captured when the drone was moving or not moving. If the drone was moving, can you attach another image which is captured when the drone is not moving?
Imx519 is using rolling shutter which could cause Roller effect and can not focus very well when moving.
Hi Dion,
Thanks for responding. We have tried it both when hovering, and when moving. When hovering though the drone does still slightly move as expected with a drone. However both times still get the effect. Its not always though - sometimes moving and hovering the capture is great.
Is there a better camera you can recommend for my use case though? i.e. taking aerial shots between 60-100m whilst still and moving?
