Modify config file. Not much luck
B0095 and B0158
Linux
Online docs
Yes, works. now having problems modifying config
Hi there,
Is it possible to get more documentation on the USB Camera Shield Vendor Commands please? Specifically the USB2.0 Vendor Command Codes, Iām using USB2 Camera Shield Rev D.
Looking at the top of https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield/blob/master/Config/USB2.0_UC-391_Rev.D/DVP/OV5640/OV5640_auto_facu_JPG_8b_2592x1944_8fps.cfg I see
[board parameter]
VRCMD = 0xD7, 0x4600, 0x0100, 1, 0x05
VRCMD = 0xD7, 0x4600, 0x0200, 1, 0x03
VRCMD = 0xD7, 0x4600, 0x0300, 1, 0xC0
VRCMD = 0xD7, 0x4600, 0x0300, 1, 0x40
VRCMD = 0xD7, 0x4600, 0x0400, 1, 0x00
VRCMD = 0xD7, 0x4600, 0x0A00, 1, 0x02
None of these seem to have any explanation in the SDK docs? https://www.arducam.com/downloads/shields/USB_Shield/ArduCAM_USB_Camera_SDK_Guide_V1.3.pdf Can you please provide a full vendor command list?
One reason Iām asking this is that Iām trying to modify the config to get the camera to return YUV instead of JPG (I donāt care about slow frame rate at this point) and itās not clear if the Vendor Commands at the top of the file need to be modified to support this. If you also have a config file to support OV5640 in YUV on the USB 2 Shield Rev D then that would be much appreciated.
Many thanks
Alan
Docs for vendor commands and extra config file if possible
