UVC serial tool: b0200 camera name change not reflected in Device Manager, grayscale video
Hi, hoping someone here can help. We’ve got Arducam USB cameras (b0200, we ordered them back in February) and the UVC serial tool doesn’t seem to be working right on them.
I followed the guide on the Arducam site for modifying the UVC camera serial number to change the camera name. The write seems to go through, but the name never actually changes in Windows Device Manager. I’ve uninstalled the device and re-plugged the camera and it still shows the old name. A few other odd things:
  • The green progress bar doesn’t fill all the way up after it says it’s done.
  • If I read the name back from the camera with the UVC serial tool, it does show the new name I set.
  • After changing the name, the video comes through in grayscale.
The confusing part is the firmware tool works fine on these same cameras, and if I use the firmware tool to reset them it works too — cameras go back to “arducam” and the video is in color again. So it seems specific to the UVC serial tool. Any idea what’s happening?
Thanks for the detailed writeup, that’s really helpful. A few things to pin down before we guess:
  • Which Windows version are you on, and does Device Manager list it under Cameras or Imaging devices?
  • When the green bar doesn’t fill up, does the tool show an error at the end, or does it just report success anyway?
  • What name string were you setting? Length of the string matters here.
Just to confirm I’ve got it right: firmware tool = works fine. UVC serial tool = name doesn’t stick and video goes grayscale. Is that the picture?
Just checking in — did my earlier post come through? Would appreciate any suggestions.
To answer your questions: it’s Windows, and Device Manager shows it as a camera. The tool reports it completes, but the green bar just doesn’t reach the end. The name I was setting wasn’t anything crazy, but it was definitely longer than a couple of characters. Firmware tool = fine, UVC serial tool = the troublemaker.
I raised this with our hardware engineer. The likely cause is a limitation on the length of the character field for the camera name, so the write partially succeeds and then things get weird after a re-enumeration.
Two things to try:
  1. Set a much shorter camera name. Delete the “Arducam USB Camera” entry in Device Manager first, then set the name to something like 001, 002, etc., and re-plug.
  2. Try modifying the serial number instead. If you can change the serial number successfully and the image comes back normal, that tells us the write path itself is fine and the problem is specific to the name field.
I’ve also sent you an updated firmware package through private message in case you need to reprogram the camera — please check your messages. Let us know what you find.
Tried the shorter name route — set the USB name to just 001 and got the exact same problem as before. Still breaks after reinstall/replug.
One detail that might help you: if I change the name and do NOT uninstall/re-plug, it seems to work normally in amcap.exe, but the USB name in Device Manager is still “Arducam USB Camera”. It only goes wrong once I reinstall or re-plug the camera. Changing the USB name to 001 gives the same failure as the longer name.
The serial number route, though, works — after changing the serial number the cameras came back and work normally.
Thanks, that’s a good data point. So the serial number can be modified and the camera works normally afterwards — that confirms the write path is fine, and it’s specifically the name field that’s misbehaving.
One question for you: can your application display the serial number rather than the camera name, so you can tell each camera apart? In our engineer’s view, the system really only recognizes the serial number. If your app can only show the camera name, then the software side would probably need to be optimized to match what you’re after.
I’ll re-test the camera here to see if there’s any other way to achieve what you need, and follow up.
Honestly, I don’t think the software we’re using can use the serial numbers of the webcams to identify them. I’ll see if I can make it work somehow.
Understood. Just to summarize where we’ve landed:
  • The name-change path through the UVC serial tool looks like it’s hitting a character-field length limitation. Even a short name like 001 reproduces the same failure after a reinstall/replug, and the grayscale video only clears after a firmware reset.
  • The serial number modification path does work, and the cameras run normally with a modified serial number. If your application can read/display the camera serial number, that’s the current workaround for telling the cameras apart.
  • If it truly can only show the camera name, we’ll need to look at optimizing the software side — I’ll follow up once I’ve re-tested the camera on our end.
