16MP High-Res camera from Kickstarter campaign -
B0386 -
Raspberry Pi Zero 2 W -
Instructions you have followed.
Followed the instructions from Plug-and-play Raspberry Pi USB webcam - Raspberry Pi
The only difference is using the 64-bit version of “Raspberry Pi OS Lite” (Bullseye) instead of the 32-bit version.
Otherwise to support the imx519, I followed the instructions from Quick Start - Arducam Wiki
The host computer (Intel iMac running macOS 10.15.7) does not detect the Pi-based WebCam though it is seen as a “UVC Gadget” from Apple System Information (USB section). The Camera section of Apple System Information does not report the WebCam. -
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi Zero 2 W Rev 1.0
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000bc00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 843419
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 112896
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i smsc95xx.macaddr=B8:27:EB:2C:78:95 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=333e6cd1-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 163088K/458752K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 33520K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] Root IRQ handler: bcm2836_arm_irqchip_handle_irq
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000390] Console: colour dummy device 80x25
[ 0.001393] printk: console [tty1] enabled
[ 0.001482] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001550] pid_max: default: 32768 minimum: 301
[ 0.001743] LSM: Security Framework initializing
[ 0.002032] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.002095] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.004059] cgroup: Disabling memory control group subsystem
[ 0.007364] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.007415] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.007711] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.008067] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.008741] rcu: Hierarchical SRCU implementation.
[ 0.008779] rcu: Max phase no-delay instances is 1000.
[ 0.010638] EFI services will not be available.
[ 0.011446] smp: Bringing up secondary CPUs …
[ 0.013174] Detected VIPT I-cache on CPU1
[ 0.013355] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.015156] Detected VIPT I-cache on CPU2
[ 0.015294] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.017087] Detected VIPT I-cache on CPU3
[ 0.017232] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.017468] smp: Brought up 1 node, 4 CPUs
[ 0.017632] SMP: Total of 4 processors activated.
[ 0.017668] CPU features: detected: 32-bit EL0 Support
[ 0.017702] CPU features: detected: 32-bit EL1 Support
[ 0.017739] CPU features: detected: CRC32 instructions
[ 0.017936] CPU: All CPU(s) started at EL2
[ 0.017992] alternatives: applying system-wide alternatives
[ 0.020629] devtmpfs: initialized
[ 0.045723] Enabled cp15_barrier support
[ 0.045814] Enabled setend support
[ 0.046176] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.046254] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.059865] pinctrl core: initialized pinctrl subsystem
[ 0.061325] DMI not present or invalid.
[ 0.062379] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.074442] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.074895] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.076485] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.076684] audit: initializing netlink subsys (disabled)
[ 0.077143] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.078197] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.078333] cpuidle: using governor menu
[ 0.079060] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.079388] ASID allocator initialised with 32768 entries
[ 0.079679] Serial: AMBA PL011 UART driver
[ 0.097805] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.113731] platform 3f801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/imx519@1a
[ 0.120769] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:52:42, variant start
[ 0.124790] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.137679] KASLR enabled
[ 0.193719] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.200456] SCSI subsystem initialized
[ 0.200865] usbcore: registered new interface driver usbfs
[ 0.200984] usbcore: registered new interface driver hub
[ 0.201115] usbcore: registered new device driver usb
[ 0.201761] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.202180] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.202676] pps_core: LinuxPPS API ver. 1 registered
[ 0.202716] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.202788] PTP clock support registered
[ 0.204553] vgaarb: loaded
[ 0.205798] clocksource: Switched to clocksource arch_sys_counter
[ 0.206927] VFS: Disk quotas dquot_6.6.0
[ 0.207070] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.207400] FS-Cache: Loaded
[ 0.207699] CacheFiles: Loaded
[ 0.222227] NET: Registered PF_INET protocol family
[ 0.222621] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.224339] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.224418] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.224619] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.224732] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.224959] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.225187] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.225261] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.225614] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.226736] RPC: Registered named UNIX socket transport module.
[ 0.226783] RPC: Registered udp transport module.
[ 0.226819] RPC: Registered tcp transport module.
[ 0.226853] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.226910] PCI: CLS 0 bytes, default 64
[ 0.229631] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.230145] kvm [1]: IPA Size Limit: 40 bits
[ 0.231960] kvm [1]: Hyp mode initialized successfully
[ 2.018776] Initialise system trusted keyrings
[ 2.019475] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 2.032767] zbud: loaded
[ 2.037560] NFS: Registering the id_resolver key type
[ 2.037650] Key type id_resolver registered
[ 2.037687] Key type id_legacy registered
[ 2.037940] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.037990] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.040179] Key type asymmetric registered
[ 2.040227] Asymmetric key parser ‘x509’ registered
[ 2.040378] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.040837] io scheduler mq-deadline registered
[ 2.040883] io scheduler kyber registered
[ 2.050185] simple-framebuffer 1eaa9000.framebuffer: framebuffer at 0x1eaa9000, 0x151800 bytes
[ 2.050266] simple-framebuffer 1eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[ 2.054073] Console: switching to colour frame buffer device 90x30
[ 2.059096] simple-framebuffer 1eaa9000.framebuffer: fb0: simplefb registered!
[ 2.072252] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.075355] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 2.081523] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.104759] brd: module loaded
[ 2.121275] loop: module loaded
[ 2.124409] Loading iSCSI transport class v2.0-870.
[ 2.134127] usbcore: registered new interface driver r8152
[ 2.136231] usbcore: registered new interface driver lan78xx
[ 2.138274] usbcore: registered new interface driver smsc95xx
[ 2.140915] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.143215] dwc_otg: FIQ enabled
[ 2.143233] dwc_otg: NAK holdoff enabled
[ 2.143249] dwc_otg: FIQ split-transaction FSM enabled
[ 2.143275] Module dwc_common_port init
[ 2.144071] usbcore: registered new interface driver uas
[ 2.146027] usbcore: registered new interface driver usb-storage
[ 2.148210] mousedev: PS/2 mouse device common for all mice
[ 2.156486] sdhci: Secure Digital Host Controller Interface driver
[ 2.158363] sdhci: Copyright(c) Pierre Ossman
[ 2.161037] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.165424] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.167767] hid: raw HID events driver (C) Jiri Kosina
[ 2.169838] usbcore: registered new interface driver usbhid
[ 2.171600] usbhid: USB HID core driver
[ 2.173721] bcm2835_vchiq 3f00b840.mailbox: there is not valid maps for state default
[ 2.187767] NET: Registered PF_PACKET protocol family
[ 2.189765] Key type dns_resolver registered
[ 2.193677] registered taskstats version 1
[ 2.195495] Loading compiled-in X.509 certificates
[ 2.198537] Key type .fscrypt registered
[ 2.200116] Key type fscrypt-provisioning registered
[ 2.229367] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.231221] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
[ 2.240019] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.242505] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.247670] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.249477] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.276228] sdhost: log_buf @ 00000000a8c25bee (c2f8b000)
[ 2.325913] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.334986] of_cfs_init
[ 2.336962] of_cfs_init: OK
[ 2.340358] Waiting for root device PARTUUID=333e6cd1-02…
[ 2.363758] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.368861] mmc0: new high speed SDHC card at address b368
[ 2.372720] mmcblk0: mmc0:b368 NCard 29.1 GiB
[ 2.380054] mmcblk0: p1 p2
[ 2.382845] mmcblk0: mmc0:b368 NCard 29.1 GiB
[ 2.404529] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.406434] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.424795] mmc1: new high speed SDIO card at address 0001
[ 3.294423] EXT4-fs (mmcblk0p2): recovery complete
[ 3.384103] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 3.387830] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.400008] devtmpfs: mounted
[ 3.414570] Freeing unused kernel memory: 4160K
[ 3.416639] Run /sbin/init as init process
[ 3.418469] with arguments:
[ 3.418485] /sbin/init
[ 3.418501] with environment:
[ 3.418516] HOME=/
[ 3.418531] TERM=linux
[ 4.247989] systemd[1]: System time before build time, advancing clock.
[ 4.568178] NET: Registered PF_INET6 protocol family
[ 4.572623] Segment Routing with IPv6
[ 4.574495] In-situ OAM (IOAM) with IPv6
[ 4.752386] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.759522] systemd[1]: Detected architecture arm64.
[ 4.813704] systemd[1]: Set hostname to .
[ 6.236573] systemd[1]: Queued start job for default target Multi-User System.
[ 6.264369] systemd[1]: Created slice system-getty.slice.
[ 6.271170] systemd[1]: Created slice system-modprobe.slice.
[ 6.277391] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 6.283312] systemd[1]: Created slice User and Session Slice.
[ 6.288500] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.293646] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.299919] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.307248] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.312304] systemd[1]: Reached target Paths.
[ 6.317043] systemd[1]: Reached target Slices.
[ 6.321724] systemd[1]: Reached target Swap.
[ 6.338114] systemd[1]: Listening on Syslog Socket.
[ 6.344121] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.349489] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.356219] systemd[1]: Listening on Journal Audit Socket.
[ 6.362274] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.368484] systemd[1]: Listening on Journal Socket.
[ 6.381609] systemd[1]: Listening on udev Control Socket.
[ 6.387612] systemd[1]: Listening on udev Kernel Socket.
[ 6.393359] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 6.418557] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.430504] systemd[1]: Mounting RPC Pipe File System…
[ 6.443363] systemd[1]: Mounting Kernel Debug File System…
[ 6.456478] systemd[1]: Mounting Kernel Trace File System…
[ 6.462067] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 6.486229] systemd[1]: Starting Restore / save the current clock…
[ 6.527085] systemd[1]: Starting Set the console keyboard layout…
[ 6.540436] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 6.556986] systemd[1]: Starting Load Kernel Module configfs…
[ 6.572482] systemd[1]: Starting Load Kernel Module drm…
[ 6.586347] systemd[1]: Starting Load Kernel Module fuse…
[ 6.602450] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.614038] systemd[1]: Starting File System Check on Root Device…
[ 6.632993] systemd[1]: Starting Journal Service…
[ 6.699332] fuse: init (API version 7.37)
[ 6.723333] systemd[1]: Starting Load Kernel Modules…
[ 6.758735] systemd[1]: Starting Coldplug All udev Devices…
[ 6.789194] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.795807] systemd[1]: Mounted RPC Pipe File System.
[ 6.802585] systemd[1]: Mounted Kernel Debug File System.
[ 6.808698] systemd[1]: Mounted Kernel Trace File System.
[ 6.816965] systemd[1]: Finished Restore / save the current clock.
[ 6.826156] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 6.836533] systemd[1]: [email protected]: Succeeded.
[ 6.841005] systemd[1]: Finished Load Kernel Module configfs.
[ 6.850742] systemd[1]: [email protected]: Succeeded.
[ 6.855627] systemd[1]: Finished Load Kernel Module fuse.
[ 6.864130] systemd[1]: Finished Load Kernel Modules.
[ 6.907990] systemd[1]: Mounting FUSE Control File System…
[ 6.920930] systemd[1]: Mounting Kernel Configuration File System…
[ 6.934299] systemd[1]: Started File System Check Daemon to report status.
[ 6.947754] systemd[1]: Starting Apply Kernel Variables…
[ 6.964020] systemd[1]: [email protected]: Succeeded.
[ 6.968509] systemd[1]: Finished Load Kernel Module drm.
[ 6.974833] systemd[1]: Mounted FUSE Control File System.
[ 6.980474] systemd[1]: Mounted Kernel Configuration File System.
[ 7.099558] systemd[1]: Started Journal Service.
[ 7.587917] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 7.708874] systemd-journald[136]: Received client request to flush runtime journal.
[ 7.806557] systemd-journald[136]: File /var/log/journal/979c9fb4c064460695debc311597e9cc/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 10.640579] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.646542] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 10.646600] [vc_sm_connected_init]: start
[ 10.648112] [vc_sm_connected_init]: installed successfully
[ 10.727259] mc: Linux media interface: v0.10
[ 10.815746] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.844635] videodev: Linux video capture interface: v2.00
[ 10.998027] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.998091] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.082436] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.086457] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.088526] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.155481] i2c i2c-11: Added multiplexed i2c bus 0
[ 11.157273] i2c i2c-11: Added multiplexed i2c bus 10
[ 11.446592] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 11.542671] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 11.604783] dwc2 3f980000.usb: supply vusb_d not found, using dummy regulator
[ 11.605271] dwc2 3f980000.usb: supply vusb_a not found, using dummy regulator
[ 11.615452] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 11.615613] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 11.615714] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 11.616564] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 11.621333] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 11.622752] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 11.622810] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 11.622873] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 11.622904] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 11.622934] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 11.625195] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 11.625269] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 11.630590] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 11.631241] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 11.631324] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 11.631596] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 11.632232] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 11.633598] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 11.633651] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 11.633706] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 11.633755] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 11.633878] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 11.634669] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 11.641161] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 11.641243] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 11.648784] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 11.648884] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 11.661471] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 11.818129] dwc2 3f980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
[ 11.818703] dwc2 3f980000.usb: DWC OTG Controller
[ 11.818774] dwc2 3f980000.usb: new USB bus registered, assigned bus number 1
[ 11.818869] dwc2 3f980000.usb: irq 51, io mem 0x3f980000
[ 11.819512] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 11.819545] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.819570] usb usb1: Product: DWC OTG Controller
[ 11.819591] usb usb1: Manufacturer: Linux 6.1.21-v8+ dwc2_hsotg
[ 11.819612] usb usb1: SerialNumber: 3f980000.usb
[ 11.820920] hub 1-0:1.0: USB hub found
[ 11.821046] hub 1-0:1.0: 1 port detected
[ 11.833460] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 11.851472] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436s-sdio for chip BCM43430/1
[ 11.852405] usbcore: registered new interface driver brcmfmac
[ 11.961634] Console: switching to colour dummy device 80x25
[ 11.973360] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43436s-sdio.clm_blob failed with error -2
[ 11.975946] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 11.985495] Registered IR keymap rc-cec
[ 12.010949] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 12.018049] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 12.035384] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 12.036049] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 12.036669] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 12.037230] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 12.037760] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 12.063158] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 12.092065] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 12.100975] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 12.144051] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 12.144973] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 5 2022 21:29:56 version 7.45.96.141 (g53ba0094) FWID 01-eef9b3bf es7
[ 13.165747] ak7375 10-000c: supply vio not found, using dummy regulator
[ 13.195175] imx519 10-001a: Device found is imx519
[ 13.195631] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 14.086089] uart-pl011 3f201000.serial: no DMA platform data
[ 14.244243] 8021q: 802.1Q VLAN Support v1.8
[ 14.571891] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 14.932027] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 16.354737] configfs-gadget.g1 gadget.0: uvc: uvc_function_bind()
[ 16.355105] dwc2 3f980000.usb: bound driver configfs-gadget.g1
[ 16.747234] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.608573] dwc2 3f980000.usb: new device is high-speed
[ 17.662307] dwc2 3f980000.usb: new address 23
[ 17.704444] configfs-gadget.g1 gadget.0: uvc: uvc_function_set_alt(0, 0)
[ 17.704468] configfs-gadget.g1 gadget.0: uvc: reset UVC Control
[ 17.704486] configfs-gadget.g1 gadget.0: uvc: uvc_function_set_alt(1, 0)
[ 18.209609] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 20.528373] Bluetooth: Core ver 2.22
[ 20.528540] NET: Registered PF_BLUETOOTH protocol family
[ 20.528553] Bluetooth: HCI device and connection manager initialized
[ 20.528587] Bluetooth: HCI socket layer initialized
[ 20.528607] Bluetooth: L2CAP socket layer initialized
[ 20.528640] Bluetooth: SCO socket layer initialized
[ 20.545359] Bluetooth: HCI UART driver ver 2.3
[ 20.545395] Bluetooth: HCI UART protocol H4 registered
[ 20.545557] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 20.546047] Bluetooth: HCI UART protocol Broadcom registered
[ 21.001244] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.001275] Bluetooth: BNEP filters: protocol multicast
[ 21.001304] Bluetooth: BNEP socket layer initialized
[ 21.010534] Bluetooth: MGMT ver 1.22
[ 21.029645] NET: Registered PF_ALG protocol family -
dmesg | grep imx519
Seems to indicate that the camera is detected, but don’t know what next to do…
- What help do you need?
To get it work as a “Plug-and-play Raspberry Pi USB webcam”.
Thank you for any help!
