Using ArduCam B0597 in 4-lane mode
I have the IMX577-based B0597:
https://www.arducam.com/arducam-12-3mp-imx577-mini-size-high-resolution-camera-module-for-depthai-dm1090ffc.html
The product description says:
  • Flexible MIPI Interface – Supports 2-lane and 4-lane MIPI (default 2-lane).
I would like to use this camera with an Arduino VENTUNO Q SBC. The VENTUNO Q only has support for 4-lane IMX577 cameras.
Can anyone provide advice about how to configure the B0597 to use 4-lane mode?
I am already successfully using the ArduCam B0488 with the VENTUNO Q (following this guide). However, when I try to follow that guide using the B0597, it is not recognized by the system:
$ sudo dmesg | grep Probe
[   24.932306] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for cmk_imx577 slot:23, slave_addr:0x34, sensor_id:0x577
[   24.962870] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for cmk_imx577 slot:24, slave_addr:0x34, sensor_id:0x577
[   24.976619] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for cmk_imx577 slot:25, slave_addr:0x34, sensor_id:0x577
[   25.007431] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for cmk_imx577 slot:26, slave_addr:0x34, sensor_id:0x577
[   25.032613] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for cmk_imx577 slot:27, slave_addr:0x34, sensor_id:0x577
[   25.065456] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx219 slot:24, slave_addr:0x20, sensor_id:0x219
[   25.080013] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx219 slot:23, slave_addr:0x20, sensor_id:0x219
[   25.115738] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx219 slot:26, slave_addr:0x20, sensor_id:0x219
[   25.134272] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx219 slot:25, slave_addr:0x20, sensor_id:0x219
[   25.172264] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx219 slot:27, slave_addr:0x20, sensor_id:0x219
[   25.209790] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx477 slot:24, slave_addr:0x34, sensor_id:0x477
[   25.229745] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx477 slot:23, slave_addr:0x34, sensor_id:0x477
[   25.268925] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx477 slot:26, slave_addr:0x34, sensor_id:0x477
[   25.300770] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx477 slot:25, slave_addr:0x34, sensor_id:0x477
[   25.343519] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx477 slot:27, slave_addr:0x34, sensor_id:0x477
[   25.387911] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx708 slot:24, slave_addr:0x34, sensor_id:0x708
[   25.412642] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx708 slot:23, slave_addr:0x34, sensor_id:0x708
[   25.448416] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx708 slot:26, slave_addr:0x34, sensor_id:0x708
[   25.470942] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx708 slot:25, slave_addr:0x34, sensor_id:0x708
[   25.506613] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_imx708 slot:27, slave_addr:0x34, sensor_id:0x708
[   25.543465] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_ov5647 slot:24, slave_addr:0x6c, sensor_id:0x5647
[   25.572422] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_ov5647 slot:23, slave_addr:0x6c, sensor_id:0x5647
[   25.614660] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_ov5647 slot:26, slave_addr:0x6c, sensor_id:0x5647
[   25.643467] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_ov5647 slot:25, slave_addr:0x6c, sensor_id:0x5647
[   25.688736] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1250: Probe failed for rpi_ov5647 slot:27, slave_addr:0x6c, sensor_id:0x5647
I am reusing the plain 22-pin FFC cable I received with the B0488 to connect the B0597 to the VENTUNO Q.
When I compare the B0597 with the B0488, it appears they are identical PCBs (both labeled UC-698 Rev.E3), but I do notice a difference in the population of a resistor at one of two locations. Here on the B0597:
Is it necessary to make a hardware modification in order to configure the B0597 for 4-lane mode?
Here is the B0488, with the resistor populated at a different location:
