USB3.0 shield plus (B0317) UC-593 Rev C
Linux
4.Which instruction are you following? https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield
Yes, it works correctly with demo app
C++ app based on https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield lib can’t connect to camera and returns error code 65281. In exactly same setup USB 3.0 shield works correctly.
Any suggestions what could cause this error?
Checking linked library and running demo app
Can I see the corresponding device through lsusb?
Or you can unplug the device first, and run dmesg -w and then plug in the device to see if the device is recognized normally. If it can be recognized, you can try sudo again (just to confirm that there is no problem with the udev rules)
Hi wong, Bus 002 Device 005: ID 04b4:03f2 Cypress Semiconductor Corp. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 0cf3:e300 Atheros Communications, Inc. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub <code></code>
device is detected correctly and this is udev rule I use
I tested your udev rules, and there seems to be no problem.The udev rules should be placed in the /etc/udev/rules.d/ directory. After adding the rules, you need to run sudo udevadm control --reload and replug the device.
If you are using your own wrapper, then you may need to pay attention to:
After calling the scan method, you need to delay two seconds before calling the open method. (a hardware bug)
