Unknown device error when modifying B0200 camera serial numbers on two PCs
Hi, I’m trying to modify the device name/serial number on my B0200 cameras following this article: Redirecting...
I have four B0200 cameras. When I run the serial number program it just pops up an error saying “unknown device”. I tested per the recommendations and it still comes up with the same error.
Environment: Windows 10, four B0200 cameras. I’ve tried all four cameras on two different PCs, tried multiple different USB ports, and even disconnected everything except the camera. Same error every time.
The cameras themselves seem fine — they show up in OBS, in amcap.exe, and in the built-in Windows 10 camera app. Not sure what I’m missing. Any ideas?
Thanks for the details. A few things to check before we go further.
First, confirm the camera can be used normally before you modify the serial number — use AMCap.exe to preview the UVC camera. Then make sure you have turned off preview apps like AMCap.exe before you start modifying the serial number. If a preview app still holds the device, the tool won’t be able to talk to it properly.
Also try replugging the camera several times to test it, and if other USB devices are connected, remove them so they aren’t occupying bandwidth.
Could you share a screenshot of the exact error information? And if it still fails, please send clear pictures of each camera (both front and back) so I can check the hardware revision.
Tried all of that. I quit amcap.exe before running the tool, reseated the camera across different USB ports, and unplugged every other USB device — still “unknown device”.
Also re-tested after the error and amcap.exe can still use the camera just fine. I’ve now run all four cameras on two different PCs with the same result every time.
Attaching front and back photos of each camera as requested.
Got the photos, thanks. One thing stands out: the camera in the first picture is a DIFFERENT version. The rest of the cameras are the same as the unit I have here on my bench, so I can reproduce with those.
My working hypothesis right now is that the hardware of that camera may have been changed by being used. Two questions to help narrow the root cause:
  1. Did you turn off amcap.exe before modifying the serial number?
  2. Did you try to use the camera again after detecting the ‘unknown device’ error?
For reference, my test procedure here is: test environment Windows 10, test product B0200 (IMX291), plug in the USB camera, download the UVC serial number tool, then press ‘read’. If you can match that on a machine with nothing else connected, that’s our cleanest baseline.
Answers:
  1. Yes — I confirmed I quit amcap.exe before trying the serial number program.
  2. Yes — after the “unknown device” error, amcap.exe is able to use the camera just fine.
Also, one of the four cameras is a different version from the others (that’s the one in the first picture). I had already tried all four cameras on two different PCs, disconnecting everything but the camera, and using different USB ports — still the same “unknown device” error.
Article I’m following: https://www.arducam.com/docs/uvc-camera-module/modify-arducam-uvc-camera-serial-number/
Thanks — that helps rule a few things out. So current state of things:
  • One of your four cameras is a different hardware version (first picture); the other three match the unit I tested. The hypothesis is that the hardware may have been altered through use, but that’s still under investigation.
  • Turning off the preview app (amcap.exe) before modifying the serial number is critical, and you’re already doing that. So that doesn’t look like the cause here.
  • The camera still working in amcap.exe after the “unknown device” error is a useful diagnostic point — it means the device isn’t dead.
Right now I don’t have a confirmed fix to give you. Two things to keep the investigation moving:
  1. Try to replug the camera several times to test it, and remove any other device that may be occupying bandwidth.
  2. Run the read step against one camera on a clean Windows 10 machine with only that camera connected (plug in the USB camera, open the UVC serial number tool, press ‘read’) and post the exact output plus a screenshot of the error.
Keep the front/back photos of each camera handy since the revision difference matters. I’ll follow up once I have more from the hardware side — this is still under investigation, so no confirmed workaround beyond confirming the camera works normally in AMCap first and ensuring no preview app is running during the modify step.
