nemi03
January 25, 2024, 10:06am
1
Searching online I wasn’t able to find the sensor on the board I reported on the following picture
For sure it isn’t an imx477 since i already tried the correspondent driver and no cameras resulted available using libcamera-hello.
Someone who can help identifing this sensor and its correspondent driver?
Thank you all in advance!
Dion
January 26, 2024, 5:31am
2
Hi
There is a pivariety chip on the camera board. I suspect that it is one of pivariety cameras, hence, please try the pivariety driver.
add the sentence below in the config file:
dtoverlay=arducam-pivariety
If you want to drive this camera, you also need to install custom libcamera from libcamera. Please run the commands:
https://docs.arducam.com/Raspberry-Pi-Camera/Pivariety-Camera/Libcamera-User-Guide/
That’s a Arducam 18MP AR1820HS
Buy Now High Resolution: 18MP AR1820HS color sensor, up to 4986 x 3684@6fps. ISP Support: Auto Exposure, Auto White Balance, lens shading. Gstreamer support. Wide Compatibility: Compatible with all libcamera-based apps maintained by the...
Est. reading time: 2 minutes
nemi03
January 29, 2024, 8:43am
4
thanks a lot for your help guys!!!
Dion
January 29, 2024, 9:06am
5
Have you fixed your problem? IF so, may you click the “solution” and we could close this thread :-))
