./install_pivariety_pkgs.sh: line 543: [: too many arguments
Huge letdown by Arducam. The Hawkeye was painful and never worked as advertised. Now i can’t get the owlsight to work And your forum post on it went unanswered for the last 18 days so I don’t have a lot of hope.
I was using Bullseye previously because the Hawkeye wouldn’t work on Bookworm, but I moved to Bookworm and the install process for the Owlsight worked. I’m not sure if the Hawkeye will still work though.
I am in the same boat as you right now. I can’t use the cameras on RPi5 without the software being fixed up. Feel free to put some pressure on in the Pull Request like I have.
I ran into this exact error, I fixed it by changing line 543 to:
if [ "$VERSION" = '6.1.21' ] && [ "$package" = "64mp" ]; then
You may need to fix the syntax as necessary, look at the quote structure.
The online documentation stops there, seemingly assuming the driver was installed. But I saw that all it did was download a .txt file with some links, so I downloaded the driver (your driver link will differ):
