Amazon
13MP AR1335 OBISP MIPI Camera Module
Pi 4
https://www.arducam.com/docs/arducam-obisp-mipi-camera-module/3-use-on-raspberry-pi/3-9-test-samples/
To be decided
I am having issues with my python program taking consistent pictures and setting camera properties for optimal photographs with opencv using the same method as the documentation linked above.
I am able to successfully see the picture of the camera change according to settings when I use the shell programpi@raspberrypi:~ $ v4l2-ctl -d /dev/video0 -c exposure=50000
pi@raspberrypi:~ $ v4l2-ctl -d /dev/video0 -c white_balance_automatic=1
pi@raspberrypi:~ $ v4l2-ctl -d /dev/video0 -c zoom=2
I can observe these changes when streaming with gstreamer over netcat (arducamstill -t 0 -e h264 -o stdout | nc -l -p 5000) or using arducamstill. I can get the picture to look the way I want this way.
When I use OpenCV within python I do not see that these changes. First I tried setting them like in the example linked above.
subprocess.call([‘v4l2-ctl -d /dev/video0 -c ircut=1’],shell=True)
I noticed that opencv may have its own way to set attributes. So I tried this:
cap = cv2.VideoCapture(0)
cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter.fourcc(*“UYVY”))
cap.set(cv2.CAP_PROP_FRAME_WIDTH,4160) #set width
cap.set(cv2.CAP_PROP_FRAME_HEIGHT,3120) #set height
cap.set(cv2.CAP_PROP_AUTO_EXPOSURE, 0)
cap.set(cv2.CAP_PROP_GAMMA, 4000)
cap.set(cv2.CAP_PROP_AUTO_WB, 0)
Other than setting the correct resolution I am not able to see any changes in the picture I have taken. They look very unusual and over-exposed without changing these settings. I used code to attempt to find supported settings:
supported = list()
for attr in dir(cv2):
if attr.startswith(‘CAP_PROP’):
if cap.get(getattr(cv2, attr)) != -1:
print(attr)
And I receive the following:
CAP_PROP_AUTO_WB
CAP_PROP_BACKEND
CAP_PROP_BUFFERSIZE
CAP_PROP_CONTRAST
CAP_PROP_CONVERT_RGB
CAP_PROP_FORMAT
CAP_PROP_FOURCC
CAP_PROP_GAIN
CAP_PROP_GAMMA
CAP_PROP_MODE
CAP_PROP_POS_MSEC
CAP_PROP_SATURATION
CAP_PROP_SHARPNESS
CAP_PROP_TEMPERATURE
CAP_PROP_WB_TEMPERATURE
CAP_PROP_ZOOM
It seems like these should be supported but I am not seeing the properties do anything (aside from resolution)
Here is a photo with arducamstill
Here is a similar photo with opencv
The opencv looks very odd because I cannot adjust the properties
Described in post
Please help me figure out how to adjust exposure, brightness, gamma etc that affect OpenCV photos in python
ircut=0
