RobotShop
2x ov9281
Raspberry Pi 4b 4GB - Raspibian Buster 32 bit - Kernel 5.10
https://www.arducam.com/docs/cameras-for-raspberry-pi/migrated/ov9281-1mp-global-shutter-raspberrypi-camera/#13-1-check-your-firmware-support
Im trying to get it to work with V4l2 but so far that has never worked.
Hello!
I have just tried my two ov9281’s but I don’t seem to be able to get any images of them. I’m trying to use them with V4L2 as I have previous camera code that uses that (which works for Picam2) and now I want to run it with my Arducam.
I’m expecting to get some output from this command:
v4l2-ctl --stream-mmap --stream-count=-1 -d /dev/video0 --stream-to=/dev/null
but I get nothing at all. It just sits, does not return to the prompt, but there’s no output in the terminal.
I have two of the same camera and they both do the same thing.
Here’s some additional hints,
> uname -a
Linux sensitpi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
> ls /boot/overlays/ov9281.dtbo
> v4l2-ctl -d /dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: ‘Y10P’ (10-bit Greyscale (MIPI Packed))
[1]: 'Y10 ’ (10-bit Greyscale)
[2]: ‘GREY’ (8-bit Greyscale)
> vcgencmd get_camera
supported=1 detected=0
> modinfo ov9281
filename: /lib/modules/5.10.17-v7l+/kernel/drivers/media/i2c/ov9281.ko
license: GPL v2
description: OmniVision ov9281 sensor driver
srcversion: D2FE2B5C96C7451BC7EFDC9
alias: of:NTCovti,ov9281C*
depends: videodev,v4l2-fwnode,mc
intree: Y
vermagic: 5.10.17-v7l+ SMP mod_unload modversions ARMv7 p2v8
> sudo tee /sys/class/video4linux/video0/dev_debug <<< 0x1f >/dev/null
> sudo dmesg
[ 81.300990] unicam fe801000.csi: ================= START STATUS =================
[ 81.301010] unicam fe801000.csi: -----Receiver status-----
[ 81.301028] unicam fe801000.csi: V4L2 width/height: 1280x800
[ 81.301045] unicam fe801000.csi: Mediabus format: 0000200a
[ 81.301061] unicam fe801000.csi: V4L2 format: 50303159
[ 81.301076] unicam fe801000.csi: Unpacking/packing: 0 / 0
[ 81.301091] unicam fe801000.csi: ----Live data----
[ 81.301106] unicam fe801000.csi: Programmed stride: 0
[ 81.301122] unicam fe801000.csi: Detected resolution: 0x0
[ 81.301137] unicam fe801000.csi: Write pointer: 00000000
[ 81.301152] unicam fe801000.csi: ================== END STATUS ==================
Are you able to tell what’s wrong here?
Or do you have any suggestions for what to check next?
Regards
Fred
