I bought the Arducam 18MP AR1820HS camera module for Raspberry Pi Pivariety and was able to get it working with my Raspberry Pi. I then wanted to use it with my Windows computer so I bought the ArduCAM USB3.0 Camera Shield Plus. I installed the drivers and the Demo GUI Software. When using the GUI USBTest.exe I’m able to scan and find the USB Camera Shield, but no matter what config file I use for the AR1820HS, I keep getting [16:38:08]USB transfer timeout error with no data coming from the camera.
I currently have the AR1820HS plugged into a UC-667 board, and that plugs into the Camera Shield. I also tried using a 22 pin ribbon cable to connect the camera sensor directly to the Camera Shield, but it won’t even turn on when I do that.
Any ideas on how to get my AR1820HS to work with the USB3.0 Camera Shield Plus?
You need to remove the UC-667 adapter and connect the AR1820 directly to the USB Camera Shield, can you provide hardware connection photos and software screenshots?
