Troubleshoot No Camera Detected - IMX519 Autofocus Synchronized Quad-Camera
I am trying to setup my rasp pi camera quad camera kit, but no camera is being detected. I have tried both the Rasp Pi OS (Legacy) 32-bit and 64-bit and both did not work (not sure if that matters).
This is my config file:
http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=imx519
Could you post the output of the commands below?
dmesg | grep imx519
dpkg -l | grep libcamera
pi@raspberrypi:~ $ dmesg | grep imx519
[ 0.071228] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/imx519@1a
[ 8.675226] imx519 10-001a: failed to read chip id 519, with error -5
[ 8.809066] imx519: probe of 10-001a failed with error -5
pi@raspberrypi:~ $ dpkg -l | grep libcamera
ii libcamera-apps 1.2.1-1 arm64 libcamera-apps
ii libcamera-dev:arm64 0~git20230724+ad9428b4-1 arm64 complex camera support library (development files)
ii libcamera0:arm64 0~git20230724+ad9428b4-1 arm64 complex camera support library
ii python3-libcamera 0~git20230720+bde9b04f-1 arm64 complex camera support library (Python 3 bindings)
Hi @Hollywood
Can you send us pictures of the hardware connection :slight_smile:
I keep getting an error whenever I try to use to preformatted chat and upload image. I am not sure if it is an issue with the forum or my own.
This is a google drive link to the photos showing the hardware connectings:
https://drive.google.com/drive/folders/1-2am2H7_XqLwNCgXeMxxzbFMFFYy___A?usp=sharing
Hi @Hollywood
Why did you use four Raspberry Pi MIPI cables? Did you try the original cable?
I did try the original ribbon cables, but I wasn’t sure if it the camera connection issue or being undetected was due to due raspbery pi ribbon cables being bent. However, even with the new ones are not connecting.
I’m curious if this quad kit could work as expected with the original cable once you receive it.
