Trouble focusing the camera
UCTRONICS
B0167B8 . It’s an IMX219 8 MP camera.
Raspberry 4B 8GB
Combination of things
Never got focused images.
After you guys sent me a replacement motor control board, the servos all work now. However, the image that results is very out of focus, even after using the autofocus function in the focuserExample.py script. The image is so blurry that nothing can be made out. Do I have to make some manual adjustments to the lens before it will focus correctly?
Here is an example picture:
Thanks a lot,
Alex
Reset camera (R) and ran autofocus (ENTER) in the focuserExample.py script.
I am probably doing something stupid, but I don’t have much experience with this.
Hi @Mewit,
I have exactly the same problem, have you been able to solve it ?
please let me know if you were able to solve it.
thanks.
Sometimes, you need to manually adjust the focal length of the lens, because the stroke of the motor is fixed and there is a certain focus range
