四相机套件按手册配置后仍检测不到摄像头
使用四相机套件时检测不到摄像头。硬件连接都没有问题,所有配置也都按照手册配置好了,但摄像头还是检测不到。有没有人遇到过类似的情况?
Can you post pictures of the hardware connection at both the Raspberry Pi end and the camera end? That will help us rule out a physical wiring issue.
In the meantime, please also generate a diagnostic report for us. Reboot your device first, then run:
This will create an arducam-bug-report.txt file in the current directory. Please attach that file here so we can take a closer look.
已经按要求提供了所有信息,下面是 arducam-camera-bug-report 工具生成的报告。
arducam-bug-report.zip
Thanks for the report. Just to confirm — which multi-camera kit did you purchase? Is it the 四目708 (four-camera 708) kit?
If it is the 四目708, the dtoverlay=arducam-pivariety overlay can prevent the kit from being detected. Please comment out or delete that line in your config.txt, then reboot the Raspberry Pi for the change to take effect.
购买的是四目708。我已经删除了 dtoverlay=arducam-pivariety,重启后还是无法打开摄像头。下面是两端的连接照片:
Thanks for confirming and for the photos. To summarize where we are: the dtoverlay=arducam-pivariety overlay was a known conflict for the 四目708, and you’ve removed it, but the cameras are still not detected after a reboot. So that overlay doesn’t appear to be the cause here. Please leave it commented out for now.
I’m going through the bug report and the connection photos to see what else could be preventing detection. I’ll follow up once I’ve finished reviewing them.
