Sync Two IMX477 Modules for Stereo Vision
    UCtronics
    B0273: Arducam 12MP IMX477 Motorized Focus High Quality Camera for Jetson Nano/Xavier NX
    Jetson Xavier NX
    Two cameras installed to Xavier NX on custom board. Using the Arducam drivers installed from https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh
  5. Problems you were having?
    Cameras work, but not sure how to enable sync
We are using two of the IMX477 camera modules to implement a stereo depth system. To get accurate stereo depth maps, we need the cameras to be in sync. I see an older driver allows for syncing ( Sync Multiple IMX477 High Quality Camera over Multiple Jetson Nano Master slave - YouTube), but this driver is not supported on the most recent JetPack. How do you enable syncing via XVS on the current driver? Is there another way of synchronizing frames with this hardware setup?
We will eventually need to enable FSTROBE too for a strobe lighting system to avoid blur. How can this be set up?
thanks in advance.
Unfortunately, we do not continue to maintain the master/slave mode driver, because it has some instability, if you want to adapt it yourself, you can contact [email protected], we can provide the source code of the old version.
The latest version of this driver I found was this one: Release Automatic installation script · ArduCAM/MIPI_Camera · GitHub. Any chance this will still work on a Jetson Orin Nano Dev Kit with Jetpack 6.0? If not, what would be the steps for me to make it work?
