Amazon
OV5642
Arduino\Teensy
Library
Yes
I am attempting to send a constant stream of JPEGs to a PC. I have the data path working and am able to pipe JPEGs into MATLAB via ethernet.
I need to get high thoughput and low latency, so I begin reading the FIFO before the capture is complete. I can find the end of the JPG from the delimiter characters.
However, I am having trouble all of the ways I’m trying to do that:
If I set FRAMES_NUM to 0x00, I can read a frame over SPI. If I try to capture another one, only 0x00 is returned. If I wait ~3seconds before re-initiating the capture, it works. This is too slow though.
If I set FRAMES_NUM to 0xFF, I can see the frames arriving in series, but after some time the data stream goes to 0x00. Also, when I try to re-initiate capture, it fails. From the failing state, if I attempt to re-initiate the camera, it fails with the message that SPI is not working.
If I set FRAMES_NUM to 0x0N, I can see a stream of frames that also, goes to 0x00 after some time.
I am reading SPI using DMA in 500 byte chunks. I can see when I’m reading too fast when the data stream goes to 0xCC. Slowing down the read rate does not solve the issue.
Questions:
It seems that SPI is messing up. Is there a reset command I can send to reset it?
Why might reading multiple frams from the FIFO work and then not work within the same capture?
How I can I quickly re-init captures to avoid stutters in the JPEG stream?
Is it possible to get the unit to continuously capture without re-initializing as long as I keep up reading from SPI?
I am able execute a single capture. However, the second
Many
Question answers.
