Hi all, I’m running into a problem with my Multi Camera Board v2.2 on a Raspberry Pi 4. I’m using picamera2 to capture images from 4 cameras connected through the board, but I’m getting over 1 second of delay between frames when switching from one camera to the next. It looks like each switch requires the cameras to be turned on again, which triggers a full re-initialization every time.
My setup:
Multi Camera Board v2.2 (I know it’s quite old)
Raspberry Pi 4
picamera2 Python library
4 cameras connected via the HAT board
I’ve been capturing images sequentially from the 4 cameras and measuring the delay at >1 second per switch. My goal is fast simultaneous image capture from all 4 cameras.
Couple of questions:
Would a specific version of Raspberry Pi OS help reduce or eliminate this delay?
Is there any example code out there for fast simultaneous capture, whether for newer or older Raspberry Pi systems?
Thanks for the detailed report. I can explain what’s going on here.
The Multi Camera Board v2.2 is fundamentally a sequential switcher — it doesn’t support simultaneous capture from multiple cameras. At any given moment, your Raspberry Pi is only connected to one camera through the board. When you switch to a different camera, the board has to electrically disconnect the previous camera and establish a brand new connection to the next one. That disconnect/reconnect cycle is what triggers the re-initialization you’re seeing, and it’s the direct cause of that >1 second delay.
Unfortunately, there’s no code-based workaround for this. The delay is inherent to the hardware design of the v2.2 board — it’s just not built for fast simultaneous image capture. No amount of software optimization will eliminate the switching overhead because it’s happening at the electrical/hardware level.
As for the OS: for older hardware like the Multi Camera Board v2.2, I’d recommend running the latest version of Raspberry Pi OS (currently “Trixie”) for the most stable performance. It won’t eliminate the switching delay, but it’ll give you the best baseline stability.
If you need true simultaneous capture from multiple cameras, you’d be looking at a different hardware approach entirely — the v2.2 board simply wasn’t designed for that use case.
Thanks for the clear explanation, that makes sense. I was hoping there might be some trick to speed things up but I understand now it’s a hardware limitation. Appreciate the Trixie recommendation too — I’ll give that a try for stability at least.
