Hey everyone, I’m pulling my hair out trying to find any documentation on the I2C registers for the OV7675 camera sensor. I’ve been googling for hours and all I find are references to the OV7670, but nothing solid for the 7675. Has anyone worked with this sensor before? I’m specifically looking for the register map to handle the I2C setup — things like the device address, clock configuration registers, resolution settings, that sort of thing. Anyone have a datasheet or know where I can dig one up?
Hi there — that sounds frustrating. The OV7675 register documentation isn’t always the easiest to track down compared to the 7670. Can you share a bit more about your setup? What platform are you working on, and is this a bare sensor or a module from a particular vendor? That’ll help narrow things down.
Sure, it’s an STM32 project — I’m using an Arducam OV7675 module (the 0.3MP DVP camera one) over I2C for configuration and the parallel DVP interface for the pixel data. I’ve got the DVP side mostly figured out in terms of timing, but without the I2C register definitions I can’t even initialize the thing properly. Right now I’m stuck at the very first step — I don’t even know the correct SCCB/I2C slave address, let alone which registers control PLL setup, output format, windowing, etc. I’m basically flying blind.
Got it, that makes total sense. The OV7675 won’t output anything useful without proper I2C register initialization — you need to configure the PLL, set the output format (RGB565, YUV, etc.), define the window size, and a bunch of other parameters before the DVP data stream is valid.
The primary reference you need is the OV7675 datasheet itself, which includes the full register map. I’ve found a copy hosted here that should cover everything you need:
Take a look at this: https://elportal.pl/files/2021/08/27/240-ov7675ds.pdf
That PDF contains the complete I2C/SCCB register definitions, including the slave address (0x42 for writes, if I recall), PLL divisors, timing registers, output format selection, and all the sensor control registers you’ll need. For STM32 specifically, you’ll want to pay close attention to the SCCB protocol section — it’s essentially I2C but with a few quirks around repeated starts and ACK handling. Some STM32 HAL I2C implementations trip on that, so you might need to bit-bang or tweak your timing.
This is exactly what I was looking for — thank you! The 0x42 address lines up with what I was guessing based on some scattered forum posts, but having the actual register map is a game-changer. I can finally start writing the init sequence. Really appreciate the heads-up on the SCCB quirks with STM32 HAL too, that’ll probably save me another headache down the road.
