Running and updating arducam_64mp_camera
Hi, I updated my raspberrypi last week and I’ve been having trouble running my two 64MP Hawkeye cameras since. both cameras were working fine before and i haven’t touched the hardware. Currently I can only detect one of the two cameras and i cannot get that camera to run.
~ $ libcamera-still -t 1000 -n
[0:02:45.463491846] [1650]  INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[0:02:45.484778325] [1651]  WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam_64mp'
[0:02:45.484842937] [1651]  WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:02:45.485158144] [1651] ERROR V4L2 v4l2_device.cpp:93 'dw9807 10-000c': Failed to open V4L2 device '/dev/v4l-subdev1': Invalid argument
[0:02:45.485284960] [1651] ERROR CameraSensor camera_sensor.cpp:527 'arducam_64mp 10-001a': Lens initialisation failed, lens disabled
[0:02:45.529763944] [1651]  INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media4 and ISP device /dev/media2
[0:02:45.530229930] [1651]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:02:45.532844307] [1650]  INFO Camera camera.cpp:1033 configuring streams: (0) 4624x3472-YUV420
[0:02:45.533805983] [1651]  INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[0:02:47.377894658] [1651]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[12:cap]: Dequeue timer of 1000000.00us has expired!
[0:02:47.378004270] [1651] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:02:47.378032381] [1651] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:02:47.378065808] [1651] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:02:48.725460820] [1651]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[12:cap]: Dequeue timer of 1000000.00us has expired!
[0:02:48.725565450] [1651] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:02:48.725593524] [1651] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:02:48.725621302] [1651] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:02:50.120099321] [1651]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[12:cap]: Dequeue timer of 1000000.00us has expired!
[0:02:50.120280397] [1651] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:02:50.120361693] [1651] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:02:50.120440953] [1651] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
Additionally, when i try tu update libcamera I notic ethis line:
W: Repository is broken: libcamera0:armhf (= 0~git20230724+ad9428b4-1) has no Size information
Additional Info:
~ $ cat /proc/cpuinfo
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : a03115
Serial : 1000000092788981
Model : Raspberry Pi 4 Model B Rev 1.5
~ $ cat /etc/os-release
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/”
SUPPORT_URL=“RaspbianForums - Raspbian”
BUG_REPORT_URL=“RaspbianBugs - Raspbian”
> ~ $ cat /boot/config.txt
> # For more options~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
#dtoverlay=vc4-kms-v3d,cma-320
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
#dtoverlay=vc4-fkms-v3d
# Run as fast as firmware / board allows; possible changes: fkms to kms & ,cma-512 after v3d
#fkms= legacy display driver(not working with DRM/KMS preview); kms= recommended display driver)
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
#dtoverlay=arducam_64mp
start_x=1
gpu_mem=128
#dtoverlay=vc4-kms-v3d,cma-512
[cm4]
#dtoverlay=arducam_64mp,cam0
#gpu_mem=128
#dtoverlay=arducam-pivariety
#dtoverlay=imx519
#dtoverlay=imx519
#dtoverlay=arducam-64mp
#dtoverlay=arducam
#dtparam=i2c_vc=on
#dtparam=i2c_arm=on
 and information see
> #hdmi_safe=1
> #overscan_left=16
> #overscan_right=16
> #overscan_top=16
> #overscan_bottom=16
> # overscan.
> #hdmi_group=1
> #hdmi_mode=1
> #hdmi_drive=2
> # no display
> #sdtv_mode=2
> #arm_freq=800
> dtparam=i2c_arm=on
> #dtparam=i2s=on
> #dtparam=spi=on
> dtparam=audio=on
> start_x=1
> max_framebuffers=2
> disable_overscan=1
> [cm4]
> otg_mode=1
> [pi4]
> arm_boost=1
> [all]
> start_x=1
> gpu_mem=128
> [cm4]
> #gpu_mem=128
> #dtoverlay=imx519
> #dtoverlay=imx519
> #dtoverlay=arducam
> #dtparam=i2c_vc=on
> #dtparam=i2c_arm=on
~ $ ls /dev/video*
/dev/video0  /dev/video10  /dev/video12  /dev/video14  /dev/video16  /dev/video19  /dev/video21  /dev/video23
/dev/video1  /dev/video11  /dev/video13  /dev/video15  /dev/video18  /dev/video20  /dev/video22  /dev/video31
~ $ dpkg -l | grep libcamera
ii  libcamera-apps                       1.2.1-1                          armhf        libcamera-apps
ii  libcamera-dev:armhf                  0~git20230724+ad9428b4-1         armhf        complex camera support library (development files)
ii  libcamera0:armhf                     0~git20230724+ad9428b4-1         armhf        complex camera support library
ii  python3-libcamera                    0~git20230720+bde9b04f-1         armhf        complex camera support library (Python 3 bindings)
~ $ dmesg | grep arducam
[    0.078959] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_64mp@1a
[   10.894541] arducam_64mp: loading out-of-tree module taints kernel.
[   10.911746] arducam_64mp 10-001a: Device found Arducam 64MP.
[   10.912824] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
Hi, After i installed the required library as per instructed by arducam quick start guide, i am unable to run arducam 64mp camera. If i run “libcamera-still -t 5000” in raspberry pi 4 terminal i am getting a blank screen and also it is displaying the RPI errors. I have attatched few images here for reference.
im getting the same thing
