I have a Raspberry Pi 4, 32 bit OS; GStreamer 1.18, Arducam 64MP Hawkeye camera.
I’m trying to create an RTSP stream using GStreamer. I’m using VLC on a secondary computer to verify the stream. I’ve done this on a Jetson Nano & Arducam CSI camera and it works perfectly. This is a camera sending a stream to an NVIDIA Deepstream model.
To verify the camera, I used the following pipeline:
gst-launch-1.0 -v libcamerasrc auto-focus-mode=continuous-auto-focus ! video/x-raw, width=3744, height=1152, framerate=8/1, format=I420 ! videoconvert ! autovideosink
This works perfectly. While I’m no GStreamer expert, I would think this proves I have a raw I420 stream coming out of the camera in a way GStreamer likes.
I built the GStramer RTSP Server (test-launch) successfully as demonstrated by:
./test-launch --gst-debug=3 '( videotestsrc ! video/x-raw,width=1280,height=720,format=I420,framerate=10/1 ! queue ! x264enc ! queue ! h264parse ! rtph264pay name=pay0 pt=96 )'
This works perfectly - test pattern appears on a second computer using VLC. So this demonstrates the ability to create an RTSP stream with x-raw I420 stream.
Thus, I would expect I could substitute the testvideosrc with libcamerasrc:
./test-launch --gst-debug=3 '( libcamerasrc ! video/x-raw,width=1280,height=720,format=I420,framerate=10/1 ! queue ! x264enc ! queue ! h264parse ! rtph264pay name=pay0 pt=96 )'
0:00:00.002252699 2750 0x130f680 WARN GST_PERFORMANCE gstbuffer.c:496:_priv_gst_buffer_initialize: No 64-bit atomic int defined for this platform/toolchain!
stream ready at rtsp://127.0.0.1:8554/test
[2:28:52.686563784] [2752] INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[2:28:52.726008528] [2753] WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam_64mp'
[2:28:52.726127063] [2753] WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[2:28:52.818015917] [2753] INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
0:00:04.291297745 2750 0xf5d420e8 FIXME default gstutils.c:4025:gst_pad_create_stream_id_internal:<libcamerasrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
[2:28:52.850803303] [2758] INFO Camera camera.cpp:1033 configuring streams: (0) 1280x720-YUV420
[2:28:52.852476027] [2753] INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 1280x720-SRGGB10_1X10 - Selected unicam format: 1280x720-pRAA
0:00:24.149406551 2750 0x14c7100 WARN rtspmedia rtsp-media.c:3576:wait_preroll: failed to preroll pipeline
0:00:24.149480328 2750 0x14c7100 WARN rtspmedia rtsp-media.c:3946:gst_rtsp_media_prepare: failed to preroll pipeline
0:00:24.665921409 2750 0x14c7100 ERROR rtspclient rtsp-client.c:1087:find_media: client 0x14c1a08: can't prepare media
0:00:24.666612957 2750 0x14c7100 ERROR rtspclient rtsp-client.c:3346:handle_describe_request: client 0x14c1a08: no media
I’m assuming my understand of the source (libcamerasrc) is wrong. Has anyone created an RTSP stream w/ 64MP camera using GStreamer test-launch? I’ve done this successfully on a Jetson + Arducam. I expected this to be similar.
