IMX477 from Amazon - Model number of the product(s)?
See (1) - What hardware/platform were you working on?
Raspberry Pi 5/8GB - Instructions you have followed. (link/manual/etc.)
I did a full apt/apt-get update and upgrade. - Problems you were having?
rpicam-helloreturns saying there are no cameras detected. - The dmesg log from your hardware?
dmesg | grep imx477returns nothing - Troubleshooting attempts you’ve made?
I’m running a fresh RPi5 image and Arducam says the IMX477 is supported natively, so why doesn’t it work natively? - What help do you need?
Help!
Hi
Please send me the output of the command below:
“cat /boot/config.txt”
I hope this helps:
# http://rptl.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
dtoverlay=w1-gpio
dtparam=uart0=on
@Dion _______________
@Dion or someone, please. Can someone on this damn forum please help me!
What kind of customer support is this?
Hi
You do not enable the camera driver on the config file. Please follow the link below to enable imx477 camera driver on the config file.
I updated the config file to the following, did a reboot, and the pi still does not find the camera. Did I update the config file wrong?
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
auto_initramfs=1
#dtoverlay=vc4-kms-v3d
#max_framebuffers=2
dtoverlay=imx477
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
dtoverlay=w1-gpio
dtparam=uart0=on
I need some information.Please follow the steps below:
- Reboot your device.
- Execute the following command to download the bug report tool:
- Set executable permissions for the tool:
- Execute the tool to generate the bug report:
- This will output an “arducam-bug-report.txt” file in the current directory. Please send this file to us([email protected]) for further analysis.
