prrhh
1
Arducam IMX219 Wide Angle Camera Module for NVIDIA Jetson Nano
B0179
Jetson Xavier NX + Jetson Nano dev board
Capturing frames using jetson_utils.videoSource
- Problems you were having?
There is a concentric red / pink halo in the image. In the center it’s fine but the further out it goes, the worse it becomes. See the attached image.
n/a
Using different camera and lens
- What help do you need?
I want to capture an image without the red halo.
prrhh
2
I managed to unscrew the lens the bare sensor gives this image:
Edward
3
prrhh
4
This worked, thank you. Can you explain what settings are being tweaked there and why sometimes it’s needed and sometimes not?
Edward
5
@prrhh
It is some adjustments on isp parameters.
Generally related to your lens, the effect of different lenses is not the same, you need to use it according to the actual situation
