My dear friend it might not be obvious but there are often wider views in all areas than simple you do not want it that way Let me try to explain it in a more detail:
You have two main use cases. Planetary and Deep Sky. *
Planets are well lit by the sun so goal is to take as much as possible frames in as shortest possible time and use small percentage of them to stack. This is called Lucky Imaging*.
For Deep Sky you want to get as much as SNR (Signal to Noise Ratio). For this, to negate sensor read noise, you need to take longer exposures. As you said Earth rotates, to negate this there are sky trackers, equatorial mounts, autoguiding software… With 1/60s you have 1% signal, due to dim targets, and 99%read noise. 1s to 300s are sweet spot for most deep space targets. Also here you will want to take multiple exposures and stack them, idealy all of exposures you capture.
For both Planetary and deep sky you want only RAW, or eventually compressed LOSELESS, not lossy, video or image format. MPEG is not an option. You can use software like Backyard Nikon or Backyard EOS to capture in raw at high FPS for planetary. I use EOS 550D.
For deep space tacking software is Deep Sky Stacker, Siril, Sequator… For planetary stacking you would proably use Autostakkeret 3.0, and Registax for wavelets.
That Svbony model is bad. They have much better cameras like 405 and 905, 305 might be fine as well. Svbony would be my last choice out of offered ZWO is industry leader, Player one is new player but promising with cool ideas. You do not need telescope, lens with adapter is often used, something like Samyang 135mm f2 is briliant if you get good model. Telescope complicates things more, But mount/tracker is basicaly a must have.
This was very very brief summary
1.* There is also lunar and solar, but they can be concidered planetary as well.
2.* Lucky imaging can be used for some bright nebulas as well.
