Amazon
Arducam OV5642 5MP Plus
Arduino Nano 33 BLE Sense
I’m working off one of the built-in examples from the GitHub
The camera has output what seemed to be proper looking bytes from time to time, but I would need this to work much more consistently
Hello! I’m trying using the ArduCAM 0V5642 5MP Plus to help take pictures for a project I am working on. My goal for it right now is to be able to take a picture once it receives the proper Serial input and then output the hex bytes of the JPEG image to Serial so that my a python script on my computer can read it using PySerial. The problem I am facing is with printing the hex bytes to the Serial Monitor. I am able to print all the bytes in the FIFO to the Serial monitor, however, they don’t seem to represent a valid JPEG image file. I am figuring this for the fact that JPEG images are supposed to start with the bytes FF D8 and then end with the bytes FF D9. Here’s a PasteBin with my current code:
The current rationale of my the read_fifo_burst is that I have the Arduino read off the FIFO buffer and save the bytes in an array. Once the array hits a certain size/finds the end of the image it spits out the contents of the array and begins filling up from the beginning again. This only happens once the FF D8 (image start) bytes are found and ends when FF D9 (image end) bytes are found. However, if I simply print out all the bytes found in the FIFO buffer I find that most of the time FF D8 and FF D9 are nowhere to be found! This might correlate with the fact that the built-in host-application doesn’t work most of the time anyways with any of the example sketches. I’m eagerly awaiting any response or solution to this unusual problem! Thank you in advance for any help!
See above!
Some guidance on how to reliably get the image data off the camera module and onto the Serial monitor would be nice!
