The dmesg log from your hardware
Teil 1/2
pi@raspberrypi:~ $ dmesg
[ 0.000000] Linux version 6.1.0-rpi6-rpi-v8 ([email protected]) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.1.58-1+rpt2 (2023-10-27)
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000dc00000, size 512 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b2fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 19712 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s79144 r8192 d31448 u118784
[ 0.000000] pcpu-alloc: s79144 r8192 d31448 u118784 alloc=29*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028596
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:46:F8:6F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=f396ee21-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037300000-0x000000003b300000] (64MB)
[ 0.000000] Memory: 7452396K/8244224K available (12352K kernel code, 2172K rwdata, 4164K rodata, 4224K init, 1082K bss, 267540K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 40064 entries in 157 pages
[ 0.000000] ftrace: allocated 157 pages with 5 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000354] Console: colour dummy device 80x25
[ 0.000418] printk: console [tty1] enabled
[ 0.000487] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000515] pid_max: default: 32768 minimum: 301
[ 0.000638] LSM: Security Framework initializing
[ 0.000941] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001085] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002467] cgroup: Disabling memory control group subsystem
[ 0.004817] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004834] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005023] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.005036] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005215] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.005228] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005698] rcu: Hierarchical SRCU implementation.
[ 0.005711] rcu: Max phase no-delay instances is 1000.
[ 0.007973] EFI services will not be available.
[ 0.008537] smp: Bringing up secondary CPUs ...
[ 0.009604] Detected PIPT I-cache on CPU1
[ 0.009765] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010929] Detected PIPT I-cache on CPU2
[ 0.011058] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.012204] Detected PIPT I-cache on CPU3
[ 0.012332] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.012483] smp: Brought up 1 node, 4 CPUs
[ 0.012504] SMP: Total of 4 processors activated.
[ 0.012518] CPU features: detected: 32-bit EL0 Support
[ 0.012528] CPU features: detected: 32-bit EL1 Support
[ 0.012542] CPU features: detected: CRC32 instructions
[ 0.012686] CPU: All CPU(s) started at EL2
[ 0.012709] alternatives: applying system-wide alternatives
[ 0.014948] devtmpfs: initialized
[ 0.027496] Enabled cp15_barrier support
[ 0.027539] Enabled setend support
[ 0.027776] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.027815] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.044449] pinctrl core: initialized pinctrl subsystem
[ 0.045438] DMI not present or invalid.
[ 0.046136] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.049875] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.050183] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.051182] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.051286] audit: initializing netlink subsys (disabled)
[ 0.051581] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.052304] thermal_sys: Registered thermal governor 'step_wise'
[ 0.052395] cpuidle: using governor menu
[ 0.052680] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.052885] ASID allocator initialised with 32768 entries
[ 0.053879] Serial: AMBA PL011 UART driver
[ 0.069444] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.092393] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-10-17T15:39:16, variant start
[ 0.096406] raspberrypi-firmware soc:firmware: Firmware hash is 30f0c5e4d076da3ab4f341d88e7d505760b93ad7
[ 0.112982] KASLR enabled
[ 0.147518] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.153346] iommu: Default domain type: Translated
[ 0.153366] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.153840] SCSI subsystem initialized
[ 0.154089] usbcore: registered new interface driver usbfs
[ 0.154148] usbcore: registered new interface driver hub
[ 0.154220] usbcore: registered new device driver usb
[ 0.154652] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.155246] pps_core: LinuxPPS API ver. 1 registered
[ 0.155260] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.155286] PTP clock support registered
[ 0.156535] vgaarb: loaded
[ 0.157228] clocksource: Switched to clocksource arch_sys_counter
[ 0.157944] VFS: Disk quotas dquot_6.6.0
[ 0.158020] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.158382] FS-Cache: Loaded
[ 0.158582] CacheFiles: Loaded
[ 0.169452] NET: Registered PF_INET protocol family
[ 0.170949] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.180008] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.180126] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.180164] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.180716] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.183730] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.184495] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.184878] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.185030] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.185554] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.186434] RPC: Registered named UNIX socket transport module.
[ 0.186450] RPC: Registered udp transport module.
[ 0.186460] RPC: Registered tcp transport module.
[ 0.186471] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.186496] PCI: CLS 0 bytes, default 64
[ 0.187125] Trying to unpack rootfs image as initramfs...
[ 0.199732] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.200241] kvm [1]: IPA Size Limit: 44 bits
[ 0.201799] kvm [1]: vgic interrupt IRQ9
[ 0.202062] kvm [1]: Hyp mode initialized successfully
[ 1.115958] Freeing initrd memory: 16720K
[ 1.262633] Initialise system trusted keyrings
[ 1.263193] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.271281] zbud: loaded
[ 1.274383] NFS: Registering the id_resolver key type
[ 1.274427] Key type id_resolver registered
[ 1.274440] Key type id_legacy registered
[ 1.274557] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.274576] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.276060] Key type asymmetric registered
[ 1.276079] Asymmetric key parser 'x509' registered
[ 1.276166] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.276444] io scheduler mq-deadline registered
[ 1.276462] io scheduler kyber registered
[ 1.279632] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.291572] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.291618] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.291712] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.291809] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
[ 1.292389] brcm-pcie fd500000.pcie: setting SCB_ACCESS_EN, READ_UR_MODE, MAX_BURST_SIZE
[ 1.292885] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.292905] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.292924] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.293003] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.293318] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.297259] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.297540] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.297737] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.297869] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.407331] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.407427] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.407505] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.407799] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.408413] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.408462] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.408487] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.408533] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.408556] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.409015] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.409307] pcieport 0000:00:00.0: PME: Signaling with IRQ 31
[ 1.409833] pcieport 0000:00:00.0: AER: enabled with IRQ 31
[ 1.410463] brcm-pcie fd500000.pcie: clkreq control enabled
[ 1.411734] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes
[ 1.411755] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.412372] Console: switching to colour frame buffer device 240x67
[ 1.421182] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
[ 1.437294] iproc-rng200 fe104000.rng: hwrng registered
[ 1.437940] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[ 1.452964] brd: module loaded
[ 1.462247] loop: module loaded
[ 1.463271] Loading iSCSI transport class v2.0-870.
[ 1.469686] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.581399] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.582685] usbcore: registered new interface driver r8152
[ 1.582761] usbcore: registered new interface driver lan78xx
[ 1.582824] usbcore: registered new interface driver smsc95xx
[ 1.631778] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.631824] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.632559] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0b00040000000890
[ 1.633721] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.633759] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.633784] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.634197] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.634219] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.634234] usb usb1: Product: xHCI Host Controller
[ 1.634249] usb usb1: Manufacturer: Linux 6.1.0-rpi6-rpi-v8 xhci-hcd
[ 1.634263] usb usb1: SerialNumber: 0000:01:00.0
[ 1.635056] hub 1-0:1.0: USB hub found
[ 1.635125] hub 1-0:1.0: 1 port detected
[ 1.636074] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.636094] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.636111] usb usb2: Product: xHCI Host Controller
[ 1.636125] usb usb2: Manufacturer: Linux 6.1.0-rpi6-rpi-v8 xhci-hcd
[ 1.636139] usb usb2: SerialNumber: 0000:01:00.0
[ 1.636824] hub 2-0:1.0: USB hub found
[ 1.636920] hub 2-0:1.0: 4 ports detected
[ 1.638861] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.639228] dwc_otg: FIQ enabled
[ 1.639239] dwc_otg: NAK holdoff enabled
[ 1.639250] dwc_otg: FIQ split-transaction FSM enabled
[ 1.639266] Module dwc_common_port init
[ 1.640697] usbcore: registered new interface driver uas
[ 1.640808] usbcore: registered new interface driver usb-storage
[ 1.641916] mousedev: PS/2 mouse device common for all mice
[ 1.650369] sdhci: Secure Digital Host Controller Interface driver
[ 1.650392] sdhci: Copyright(c) Pierre Ossman
[ 1.651140] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.655344] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.655782] hid: raw HID events driver (C) Jiri Kosina
[ 1.655969] usbcore: registered new interface driver usbhid
[ 1.655982] usbhid: USB HID core driver
[ 1.667161] NET: Registered PF_PACKET protocol family
[ 1.667305] Key type dns_resolver registered
[ 1.668640] registered taskstats version 1
[ 1.668735] Loading compiled-in X.509 certificates
[ 1.698505] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.698617] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
[ 1.699531] Key type .fscrypt registered
[ 1.699546] Key type fscrypt-provisioning registered
[ 1.715794] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.716722] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.716910] fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.717204] serial serial0: tty port ttyAMA1 registered
[ 1.727199] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.727711] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.729425] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.729445] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.765363] mmc1: Controller never released inhibit bit(s).
[ 1.768427] of_cfs_init
[ 1.768562] of_cfs_init: OK
[ 1.802082] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
