I’m new to the Raspberry Pi ecosystem, but trying to get my camera working and nothing so far has worked. I’ve followed all the tutorials I could find online to ensure my raspi-config settings were proper and that I’ve installed the correct drivers & packages. Any help or suggestions are appreciated. I’m running headless with no other attachments to the Pi. The below diagnostics were executed through SSH, but I can VNC into the Pi and I’ve seen similar results.
Any help is appreciated!
libcamera-hello -t 0
Preview window unavailable [0:34:33.059623114] [3314] **INFO** **Camera** **camera_manager.cpp:293** libcamera v0.0.0+3897-c3c878a9 ERROR: *** no cameras available ***
uname -a
Linux rpi 5.15.61+ #1579 Fri Aug 26 11:08:59 BST 2022 armv6l GNU/Linux
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)" NAME="Raspbian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
cat /proc/meminfo
MemTotal: 375192 kB MemFree: 141440 kB MemAvailable: 262640 kB Buffers: 9056 kB Cached: 153024 kB SwapCached: 3140 kB Active: 118208 kB Inactive: 72384 kB Active(anon): 28120 kB Inactive(anon): 2476 kB Active(file): 90088 kB Inactive(file): 69908 kB Unevictable: 16 kB Mlocked: 16 kB SwapTotal: 102396 kB SwapFree: 4688 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 25672 kB Mapped: 29764 kB Shmem: 2084 kB KReclaimable: 12520 kB Slab: 24796 kB SReclaimable: 12520 kB SUnreclaim: 12276 kB KernelStack: 1704 kB PageTables: 4596 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 289992 kB Committed_AS: 1121772 kB VmallocTotal: 638976 kB VmallocUsed: 4908 kB VmallocChunk: 0 kB Percpu: 64 kB CmaTotal: 65536 kB CmaFree: 59588 kB
cat /boot/config.txt
# For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. #framebuffer_width=1280 #framebuffer_height=720 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces dtparam=i2c_arm=on #dtparam=i2s=on dtparam=spi=on # Uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on camera_auto_detect=1 # Automatically load overlays for detected cameras start_x=1 # Enable DRM VC4 V3D driver #dtoverlay=vc4-kms-v3d max_framebuffers=2 # Disable compensation for displays with overscan disable_overscan=1 [cm4] # Enable host mode on the 2711 built-in XHCI USB controller. # This line should be removed if the legacy DWC2 controller is required # (e.g. for USB device mode) or if USB support is not required. otg_mode=1 #added in overlay for arducam camera #dtoverlay=imx219 [all] [pi4] #dtoverlay=vc4-fkms-v3d # Run as fast as firmware / board allows arm_boost=1 dtoverlay=arducam [all] dtparam=act_led_trigger=actpwr gpu_mem=128 dtparam=i2c_vc=on
dmesg | grep -E "imx477|imx219|arducam"
[ 47.631462] **imx219** 10-0010: failed to read chip id 219 [ 47.752819] **imx219**: probe of 10-0010 failed with error -5
