Hi, hoping someone can help me figure this out before I sink too much time into it. I’ve got a Raspberry Pi Pico and an Arducam OV5642 camera module. I want to run it on Linux and drive the camera from MicroPython. I only need still images, no video or streaming at all. Is it actually possible to connect the Pico to the OV5642 under MicroPython on Linux? Or is the only realistic path to do everything on Windows? Not sure where to even start, so any pointers would be great.
Welcome! Happy to look into this with you. Before I dig in, can you confirm a couple of things so I point you the right way?
- Is this the RP2040-based Raspberry Pi Pico (the standard one), or a Pico W / Pico 2?
- Which exact OV5642 module do you have - the parallel (DVP) version or something with an SPI adapter board?
- Have you tried any MicroPython libraries yet, or is this still at the planning stage?
Just want to make sure I understand the exact hardware you’re working with.
It’s the standard Raspberry Pi Pico (RP2040), not the W. The camera is the Arducam OV5642 - it’s the parallel/DVP style module, it has that ribbon with all the data pins plus the control lines. I’m on Linux on my desktop, using MicroPython on the Pico itself.
And no, I haven’t tried anything yet. I don’t see any examples for MicroPython + OV5642 on the Pico and I didn’t want to wire everything up only to find out it can’t be done. Honestly the whole reason I’m asking is I’d rather not be forced into a Windows workflow if I can avoid it.
Got it, thanks - that’s the important detail. The OV5642 is a parallel (DVP) sensor, so it needs a lot of GPIO plus its own clock (XCLK), sync signals (VSYNC/HREF/PCLK), and an SCCB/I2C control bus. That’s a very different situation from the SPI-based Arducam modules, which do have a MicroPython route.
I’ve asked our software engineer to confirm what the current level of support is for the OV5642 specifically on the Pico under MicroPython, since I don’t want to guess on this one. Give me a bit and I’ll come back with a definitive answer.
Appreciate you checking. Yeah, that’s the thing - with all those parallel pins and clock lines I wasn’t sure the Pico could even keep up, let alone whether there’s a MicroPython driver. On the Windows side I’ve seen references to it working through some other tooling, which is why I was wondering if Linux/MicroPython was just off the table. Let me know what your engineer says.
Just heard back from our software engineer. Short version: the OV5642 on the Pico running MicroPython is not supported at the moment. There’s no working MicroPython driver for that camera on the Pico right now, so we can’t give you a path to get stills that way today.
So unfortunately there isn’t a solution I can hand you for the Linux + MicroPython setup you described. It’s not that your wiring or approach is wrong - it’s that the support just isn’t there yet on our side.
Ah, that’s a bummer but kind of what I suspected. So just to be completely clear - there’s no way to do even stills with the Pico + OV5642 under MicroPython right now? And is that a hardware limitation with the Pico, or purely a software/driver thing? Trying to figure out whether I should wait or just accept Windows is the only option for this camera.
On the stills-only question: correct, there’s no supported way to do it with the Pico + OV5642 under MicroPython at this time.
To be fair about where the limitation sits - I’d frame this as a software/driver support gap rather than a hard hardware wall. The Pico’s GPIO and clocking are capable of talking to a DVP sensor in principle, but there’s currently no MicroPython driver to actually make the OV5642 work that way, so it isn’t a supported configuration today.
I don’t want to overpromise on timing, but this is something that could be tested and potentially developed in the future. If that changes, we’d usually surface it in our docs/examples.
Understood, thanks for being straight about it instead of giving me a maybe. I’ll put the Pico + OV5642 idea on hold for now then and not go down the rabbit hole of wiring it up. If there’s nothing to try on the Linux/MicroPython side, I’ll plan around that.
That’s probably the right call for now, and sorry I couldn’t give you a working path this time.
To summarize where this landed so it’s clear for anyone reading the thread later:
- Setup: Raspberry Pi Pico (RP2040) + Arducam OV5642 (parallel/DVP) camera, Linux host, MicroPython on the Pico, stills-only use case.
- Question: can the Pico connect to and use the OV5642 under MicroPython on Linux?
- Answer: No - the OV5642 on the Pico with MicroPython is not supported at present. There’s no current MicroPython driver for this camera on the Pico, so there’s no working solution today.
- Nature of the limitation: a driver/support gap rather than a hard hardware block, but it’s not something that works as-is right now.
- Possible future: it may be tested and developed later, but there’s no confirmed timeline, so don’t count on it short term.
If anything changes on support for this combo, it should show up in our examples/docs. Feel free to post back if you go a different route and want to sanity-check it.
