I’ve got an Arducam IMX519 that my Raspberry Pi 3B just won’t recognize. I know the Pi itself is fine because I swapped in a different camera and it worked. Our IT guy also couldn’t get the IMX519 to talk on either a 3B or a 4.
I followed the setup instructions on the Arducam site, tried several code samples from there, and even wiped the Pi and started over. The camera never shows up in any command output.
Here’s the test script I’ve been running:
from picamera import PiCamera
from time import sleep
camera = PiCamera()
camera.start_preview()
sleep(5) # Wait for the camera to adjust to lighting conditions
camera.capture('/home/pi/image.jpg')
camera.stop_preview()
And this is what I get when I run it:
>>> %Run -c $EDITOR_CONTENT
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
File "/usr/lib/python3/dist-packages/picamera/camera.py", line 456, in _init_camera
self._camera = mo.MMALCamera()
File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2279, in __init__
super(MMALCamera, self).__init__()
File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 631, in __init__
mmal_check(
File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
raise PiCameraMMALError(status, prefix)
picamera.exc.PiCameraMMALError: Failed to create MMAL component b'vc.ril.camera': Out of memory
During handling of the above exception, another exception occurred:
File "", line 4, in <module>
File "/usr/lib/python3/dist-packages/picamera/camera.py", line 431, in __init__
self._init_camera(camera_num, stereo_mode, stereo_decimate)
File "/usr/lib/python3/dist-packages/picamera/camera.py", line 459, in _init_camera
raise PiCameraError(
picamera.exc.PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
Any ideas? I’ve already tried raspi-config to enable the camera.
Thanks for the detailed log. Before we dig into the config, can you generate a diagnostic report from the Pi? I’ve sent you our camera bug report tool via private message.
Once you’ve got it on the Pi, make it executable and run it:
Got the report, thanks. Looking at it, the camera isn’t actually enabled in the config file. The IMX519 needs its dtoverlay entry set up correctly, and that’s missing or incorrect in your current setup.
Found the problem with the config. My config.txt had two [All] sections, and I’d put the IMX519 dtoverlay in the top one. Deleting that top [All] block and putting the dtoverlay in the bottom [All] section fixed it — libcamera-still runs and captures images now.
But my Python script still throws the same memory error. It’s using the old picamera library. The script is on my USB drive at /media/pi/TEAM FELIX/RPi offload/PDAF Camera.py, but the test code is the same as before:
#test code
camera = PiCamera()
Logs:
>>> %Run 'PDAF Camera.py'
mmal_check(
File "/media/pi/TEAM FELIX/RPi offload/PDAF Camera.py", line 32, in <module>
camera = PiCamera()
So libcamera sees it, but picamera doesn’t. What am I missing?
Glad libcamera-still is working — that confirms the camera and the dtoverlay are fine now. The remaining error is because your Python code is still going through the legacy picamera/MMAL path, which is deprecated and doesn’t play well with the IMX519.
Switch that script over to picamera2. Here’s the user guide:
