Full dmesg for case a)
[email protected]:~ $ dmesg
[ 0.000000] Linux version 5.15.84-v7+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 11:59:48 GMT 2023
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35724 r8192 d21620 u65536
[ 0.000000] pcpu-alloc: s35724 r8192 d21620 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:[email protected] vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=ffed193d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Memory: 681100K/970752K available (10240K kernel code, 1337K rwdata, 3076K rodata, 1024K init, 569K bss, 27508K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 33312 entries in 98 pages
[ 0.000000] ftrace: allocated 98 pages with 3 groups
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000440] Console: colour dummy device 80x30
[ 0.000515] printk: console [tty1] enabled
[ 0.000577] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000607] pid_max: default: 32768 minimum: 301
[ 0.000775] LSM: Security Framework initializing
[ 0.001023] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001051] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002705] cgroup: Disabling memory control group subsystem
[ 0.002997] CPU: Testing write buffer coherency: ok
[ 0.003574] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005101] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005299] rcu: Hierarchical SRCU implementation.
[ 0.006321] smp: Bringing up secondary CPUs ...
[ 0.007543] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008921] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010238] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010405] smp: Brought up 1 node, 4 CPUs
[ 0.010433] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010453] CPU: All CPU(s) started in HYP mode.
[ 0.010464] CPU: Virtualization extensions available.
[ 0.011468] devtmpfs: initialized
[ 0.030446] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.030715] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.030754] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.043086] pinctrl core: initialized pinctrl subsystem
[ 0.044535] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.049442] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.055151] audit: initializing netlink subsys (disabled)
[ 0.055481] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.056151] thermal_sys: Registered thermal governor 'step_wise'
[ 0.057285] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.057306] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.057620] Serial: AMBA PL011 UART driver
[ 0.068558] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.100141] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:48:31, variant start
[ 0.110158] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[ 0.160937] Kprobes globally optimized
[ 0.166710] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.169110] SCSI subsystem initialized
[ 0.169415] usbcore: registered new interface driver usbfs
[ 0.169482] usbcore: registered new interface driver hub
[ 0.169554] usbcore: registered new device driver usb
[ 0.169944] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.170142] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.170484] pps_core: LinuxPPS API ver. 1 registered
[ 0.170499] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.170535] PTP clock support registered
[ 0.172787] clocksource: Switched to clocksource arch_sys_counter
[ 0.243601] VFS: Disk quotas dquot_6.6.0
[ 0.243731] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.243952] FS-Cache: Loaded
[ 0.244274] CacheFiles: Loaded
[ 0.245336] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 0.245362] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.245995] Console: switching to colour frame buffer device 240x67
[ 0.281015] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 0.291833] NET: Registered PF_INET protocol family
[ 0.292150] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.293911] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.293968] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.293994] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.294124] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.294321] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.294504] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.294568] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.294871] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.303984] RPC: Registered named UNIX socket transport module.
[ 0.304001] RPC: Registered udp transport module.
[ 0.304014] RPC: Registered tcp transport module.
[ 0.304027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.921319] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.925409] Initialise system trusted keyrings
[ 1.925783] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.935862] zbud: loaded
[ 1.937988] FS-Cache: Netfs 'nfs' registered for caching
[ 1.939005] NFS: Registering the id_resolver key type
[ 1.939052] Key type id_resolver registered
[ 1.939065] Key type id_legacy registered
[ 1.939225] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.939241] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.940584] Key type asymmetric registered
[ 1.940602] Asymmetric key parser 'x509' registered
[ 1.940736] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.940753] io scheduler mq-deadline registered
[ 1.940768] io scheduler kyber registered
[ 1.954276] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.954914] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.956278] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.968942] brd: module loaded
[ 1.979171] loop: module loaded
[ 1.979991] Loading iSCSI transport class v2.0-870.
[ 1.981973] usbcore: registered new interface driver lan78xx
[ 1.982068] usbcore: registered new interface driver smsc95xx
[ 1.982097] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.710365] Core Release: 2.80a
[ 2.710386] Setting default values for core params
[ 2.710420] Finished setting default values for core params
[ 2.910791] Using Buffer DMA mode
[ 2.910805] Periodic Transfer Interrupt Enhancement - disabled
[ 2.910819] Multiprocessor Interrupt Enhancement - disabled
[ 2.910833] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.910852] Dedicated Tx FIFOs mode
[ 2.911607] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9ed04000 dma = 0xded04000 len=9024
[ 2.911652] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.911672] dwc_otg: Microframe scheduler enabled
[ 2.911802] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.911820] WARN::hcd_init_fiq:458: FIQ ASM at 807fc54c length 36
[ 2.911841] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 2.911866] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.911910] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.911960] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.912023] Init: Port Power? op_state=1
[ 2.912035] Init: Power Port (0)
[ 2.912414] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.912438] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.912458] usb usb1: Product: DWC OTG Controller
[ 2.912474] usb usb1: Manufacturer: Linux 5.15.84-v7+ dwc_otg_hcd
[ 2.912491] usb usb1: SerialNumber: 3f980000.usb
[ 2.913368] hub 1-0:1.0: USB hub found
[ 2.913450] hub 1-0:1.0: 1 port detected
[ 2.914442] dwc_otg: FIQ enabled
[ 2.914456] dwc_otg: NAK holdoff enabled
[ 2.914468] dwc_otg: FIQ split-transaction FSM enabled
[ 2.914487] Module dwc_common_port init
[ 2.914847] usbcore: registered new interface driver usb-storage
[ 2.915079] mousedev: PS/2 mouse device common for all mice
[ 2.918745] sdhci: Secure Digital Host Controller Interface driver
[ 2.918764] sdhci: Copyright(c) Pierre Ossman
[ 2.919312] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.922112] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.922455] hid: raw HID events driver (C) Jiri Kosina
[ 2.922651] usbcore: registered new interface driver usbhid
[ 2.922667] usbhid: USB HID core driver
[ 2.928642] Initializing XFRM netlink socket
[ 2.928696] NET: Registered PF_PACKET protocol family
[ 2.928872] Key type dns_resolver registered
[ 2.929656] Registering SWP/SWPB emulation handler
[ 2.930416] registered taskstats version 1
[ 2.930453] Loading compiled-in X.509 certificates
[ 2.931377] Key type .fscrypt registered
[ 2.931393] Key type fscrypt-provisioning registered
[ 2.943973] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.944176] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 2.947015] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.947517] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.949311] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.949332] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.976438] sdhost: log_buf @ 554c04e2 (ded07000)
[ 3.026300] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.042974] Indeed it is in host mode hprt0 = 00021501
[ 3.065468] of_cfs_init
[ 3.065786] of_cfs_init: OK
[ 3.067181] Waiting for root device PARTUUID=ffed193d-02...
[ 3.086523] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.089824] mmc0: new high speed SDXC card at address 0007
[ 3.090930] mmcblk0: mmc0:0007 SD64G 59.8 GiB
[ 3.105683] mmcblk0: p1 p2
[ 3.106506] mmcblk0: mmc0:0007 SD64G 59.8 GiB (quirks 0x80000000)
[ 3.135040] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.135067] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.141714] mmc1: new high speed SDIO card at address 0001
[ 3.262872] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.263049] Indeed it is in host mode hprt0 = 00001101
[ 3.503129] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.503171] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.504139] hub 1-1:1.0: USB hub found
[ 3.504280] hub 1-1:1.0: 5 ports detected
[ 3.822820] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.953087] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.953113] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.955914] smsc95xx v2.0.0
[ 4.075558] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 4.076455] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ac:f5:53
[ 4.172819] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 4.319793] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[ 4.319819] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.319839] usb 1-1.2: Product: USB Receiver
[ 4.319856] usb 1-1.2: Manufacturer: Logitech
[ 4.331042] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C52B.0001/input/input0
[ 4.393878] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.2/input0
[ 4.406714] input: Logitech USB Receiver Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input1
[ 4.407408] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input2
[ 4.473166] input: Logitech USB Receiver System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input3
[ 4.473790] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.2/input1
[ 4.484342] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.2/input2
[ 4.582823] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[ 4.714406] usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 4.714432] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.714452] usb 1-1.4: Product: USB2.0 Hub
[ 4.715290] hub 1-1.4:1.0: USB hub found
[ 4.715659] hub 1-1.4:1.0: 4 ports detected
[ 4.812819] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[ 4.947792] usb 1-1.5: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 4.947819] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.947839] usb 1-1.5: Product: USB Optical Mouse
[ 4.947856] usb 1-1.5: Manufacturer: PixArt
[ 4.952662] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:093A:2510.0004/input/input5
[ 4.953312] hid-generic 0003:093A:2510.0004: input,hidraw3: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.5/input0
[ 5.042841] usb 1-1.4.1: new low-speed USB device number 7 using dwc_otg
[ 5.323297] usb 1-1.4.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.50
[ 5.323323] usb 1-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.323343] usb 1-1.4.1: Product: RPI Wired Keyboard 4
[ 5.323377] usb 1-1.4.1: Manufacturer:
[ 5.392281] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.0/0003:04D9:0006.0005/input/input6
[ 5.453644] hid-generic 0003:04D9:0006.0005: input,hidraw4: USB HID v1.11 Keyboard [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.4.1/input0
[ 5.508114] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.1/1-1.4.1:1.1/0003:04D9:0006.0006/input/input7
[ 5.573208] hid-generic 0003:04D9:0006.0006: input,hidraw5: USB HID v1.11 Device [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.4.1/input1
[ 8.072270] EXT4-fs (mmcblk0p2): recovery complete
[ 8.078790] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.078916] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 8.087379] devtmpfs: mounted
[ 8.095898] Freeing unused kernel image (initmem) memory: 1024K
[ 8.096463] Run /sbin/init as init process
[ 8.096479] with arguments:
[ 8.096491] /sbin/init
[ 8.096502] splash
[ 8.096513] with environment:
[ 8.096524] HOME=/
[ 8.096535] TERM=linux
[ 8.653861] systemd[1]: System time before build time, advancing clock.
[ 8.934549] NET: Registered PF_INET6 protocol family
[ 8.936523] Segment Routing with IPv6
[ 8.936579] In-situ OAM (IOAM) with IPv6
[ 9.055322] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 9.056493] systemd[1]: Detected architecture arm.
[ 9.058698] systemd[1]: Set hostname to <raspberrypi>.
[ 9.987368] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 10.247641] systemd[1]: Queued start job for default target Graphical Interface.
[ 10.255629] systemd[1]: Created slice system-getty.slice.
[ 10.257493] systemd[1]: Created slice system-modprobe.slice.
[ 10.258769] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 10.259694] systemd[1]: Created slice User and Session Slice.
[ 10.260355] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.261852] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.263355] systemd[1]: Reached target Slices.
[ 10.263727] systemd[1]: Reached target Swap.
[ 10.265278] systemd[1]: Listening on Syslog Socket.
[ 10.266180] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 10.266669] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 10.268114] systemd[1]: Listening on Journal Audit Socket.
[ 10.268952] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.270025] systemd[1]: Listening on Journal Socket.
[ 10.278101] systemd[1]: Listening on udev Control Socket.
[ 10.279231] systemd[1]: Listening on udev Kernel Socket.
[ 10.280699] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 10.286464] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.292330] systemd[1]: Mounting RPC Pipe File System...
[ 10.299558] systemd[1]: Mounting Kernel Debug File System...
[ 10.306829] systemd[1]: Mounting Kernel Trace File System...
[ 10.307689] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 10.320854] systemd[1]: Starting Restore / save the current clock...
[ 10.329467] systemd[1]: Starting Set the console keyboard layout...
[ 10.337109] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 10.344672] systemd[1]: Starting Load Kernel Module configfs...
[ 10.352533] systemd[1]: Starting Load Kernel Module drm...
[ 10.360498] systemd[1]: Starting Load Kernel Module fuse...
[ 10.385338] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 10.391779] systemd[1]: Starting File System Check on Root Device...
[ 10.406344] systemd[1]: Starting Journal Service...
[ 10.438620] systemd[1]: Starting Load Kernel Modules...
[ 10.464564] systemd[1]: Starting Coldplug All udev Devices...
[ 10.482583] fuse: init (API version 7.34)
[ 10.502262] systemd[1]: Mounted POSIX Message Queue File System.
[ 10.503530] systemd[1]: Mounted RPC Pipe File System.
[ 10.504538] systemd[1]: Mounted Kernel Debug File System.
[ 10.505583] systemd[1]: Mounted Kernel Trace File System.
[ 10.509210] systemd[1]: Finished Restore / save the current clock.
[ 10.512503] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 10.520820] systemd[1]: [email protected]: Succeeded.
[ 10.522544] systemd[1]: Finished Load Kernel Module configfs.
[ 10.526194] systemd[1]: [email protected]: Succeeded.
[ 10.529409] systemd[1]: Finished Load Kernel Module fuse.
[ 10.545019] systemd[1]: Mounting FUSE Control File System...
[ 10.552089] systemd[1]: Mounting Kernel Configuration File System...
[ 10.572832] systemd[1]: Started File System Check Daemon to report status.
[ 10.587616] systemd[1]: Mounted FUSE Control File System.
[ 10.620562] i2c_dev: i2c /dev entries driver
[ 10.634426] systemd[1]: Finished Load Kernel Modules.
[ 10.635739] systemd[1]: Mounted Kernel Configuration File System.
[ 10.641690] systemd[1]: Starting Apply Kernel Variables...
[ 10.708631] systemd[1]: [email protected]: Succeeded.
[ 10.711791] systemd[1]: Finished Load Kernel Module drm.
[ 10.760889] systemd[1]: Finished Apply Kernel Variables.
[ 10.887949] systemd[1]: Started Journal Service.
[ 11.142982] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 11.230326] systemd-journald[128]: Received client request to flush runtime journal.
[ 11.995791] systemd-journald[128]: File /var/log/journal/9c3d1142ab324d4fac61df18962344d6/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 15.767472] mc: Linux media interface: v0.10
[ 15.878158] videodev: Linux video capture interface: v2.00
[ 15.883169] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.901774] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 15.901822] [vc_sm_connected_init]: start
[ 15.914819] [vc_sm_connected_init]: installed successfully
[ 15.961702] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.965983] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.998633] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.012871] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.037882] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 16.037966] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 16.045454] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 16.045540] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 16.065234] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 16.065307] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 16.087150] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 16.087219] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 16.095841] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 16.095922] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 16.149277] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.166575] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 16.167201] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 16.168076] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 16.168498] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 16.168543] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 16.168575] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 16.168597] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 16.168633] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 16.178783] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 16.179342] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 16.179790] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 16.180156] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 16.180193] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 16.180221] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 16.180245] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 16.180267] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 16.185951] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 16.489146] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.537561] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 16.660515] i2c i2c-11: Added multiplexed i2c bus 0
[ 16.661308] i2c 10-000c: Fixing up cyclic dependency with 3f801000.csi
[ 16.661749] i2c i2c-11: Added multiplexed i2c bus 10
[ 17.271900] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 17.501382] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 17.550464] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 17.784521] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.2/input2
[ 17.814847] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 17.843405] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 17.844538] usbcore: registered new interface driver brcmfmac
[ 18.027016] input: Logitech Wireless Device PID:404d Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input8
[ 18.028760] input: Logitech Wireless Device PID:404d Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input9
[ 18.029778] hid-generic 0003:046D:404D.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:404d] on usb-3f980000.usb-1.2/input2:1
[ 18.118103] checking generic (3e402000 7f8000) vs hw (0 ffffffff)
[ 18.118143] fb0: switching to vc4 from simple
[ 18.148336] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 18.159685] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 18.183270] Console: switching to colour dummy device 80x30
[ 18.209526] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 18.283985] Registered IR keymap rc-cec
[ 18.284289] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 18.285003] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input13
[ 18.328100] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 18.329194] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 18.330394] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 18.331435] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 18.332475] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 18.336657] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 18.370161] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 18.489359] Console: switching to colour frame buffer device 240x67
[ 18.489448] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 19.632186] 8021q: 802.1Q VLAN Support v1.8
[ 19.757529] uart-pl011 3f201000.serial: no DMA platform data
[ 19.764359] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 20.008164] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 20.164379] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 22.393494] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[ 22.393560] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.913579] arducam-pivariety 10-000c: firmware version: 0x0003
[ 23.146191] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 23.256081] input: Logitech K400 Plus as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input14
[ 23.256961] logitech-hidpp-device 0003:046D:404D.0007: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-3f980000.usb-1.2/input2:1
[ 25.199291] Bluetooth: Core ver 2.22
[ 25.199432] NET: Registered PF_BLUETOOTH protocol family
[ 25.199443] Bluetooth: HCI device and connection manager initialized
[ 25.199472] Bluetooth: HCI socket layer initialized
[ 25.199489] Bluetooth: L2CAP socket layer initialized
[ 25.199519] Bluetooth: SCO socket layer initialized
[ 25.258044] Bluetooth: HCI UART driver ver 2.3
[ 25.258080] Bluetooth: HCI UART protocol H4 registered
[ 25.258204] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 25.262948] Bluetooth: HCI UART protocol Broadcom registered
[ 25.838934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.838969] Bluetooth: BNEP filters: protocol multicast
[ 25.839154] Bluetooth: BNEP socket layer initialized
[ 25.886256] NET: Registered PF_ALG protocol family
[ 25.926866] cryptd: max_cpu_qlen set to 1000
[ 26.695820] systemd-journald[128]: File /var/log/journal/9c3d1142ab324d4fac61df18962344d6/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 29.697387] Bluetooth: RFCOMM TTY layer initialized
[ 29.697437] Bluetooth: RFCOMM socket layer initialized
[ 29.697471] Bluetooth: RFCOMM ver 1.11
[ 174.201370] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
