Raspberry Pi 3 B+ Not Recognizing 64MP-AF Camera Module
Hi, I think my camera might be defective. I’ve got a Raspberry Pi 3 B+ and the Arducam 64MP-AF camera module, but the Pi just won’t recognize the camera at all. I followed all the instructions step by step and it still does nothing. Double and triple checked that the connections are solid and the ribbon is in the right orientation. Any ideas?
One thing to note: this camera (64MP-AF) was referenced in a support email with me before, so I’m on the right module. Running it on a Pi 3 B+.
Thanks for reaching out. Before we jump to conclusions, a camera not showing up on a Pi is usually a software/driver-side thing rather than a dead module, so let’s gather some diagnostics first to pin down the exact cause.
A couple of quick questions to start:
  1. Which OS image are you running (Raspberry Pi OS Bookworm/Bullseye, and 32-bit or 64-bit)?
  2. Do you get any error when you try to capture, or does it fail silently?
If you can, run a capture and paste what you see:
That output will tell us a lot.
It’s Raspberry Pi OS, and I’m pretty sure it’s the current Bookworm one but I’d have to double check the bit version. When I try to capture it just doesn’t work - no image saved and I don’t get a camera detected message. I don’t have any custom code, it’s just the standard command you gave me.
Honestly I’ve already gone through the whole instruction sheet twice. The connections feel solid and the ribbon is definitely the right way around. That’s why I’m leaning toward the module being faulty.
I hear you, and the connections being right is good to rule out. But “not recognized” can come from a few different places - a missing or mismatched libcamera package, an overlay/config issue, or the camera itself. The only way to tell them apart is to get the actual diagnostic output, so let’s grab that.
Please run these two commands on the Pi and send me the results:
  1. dpkg -l | grep libcamera
  2. camera-bug-report -t 5 -o bug.txt -c "libcamera-still -t 1000 -o test.jpg"
The first shows us which libcamera packages and versions you have installed. The second generates a bug.txt file on your Pi that captures the full camera detection state while it tries a capture. Please send me that bug.txt file.
Once I can see those, I can tell what’s actually going wrong instead of guessing.
OK that makes sense. Ran the first one - here’s what came back:
pi@raspberrypi:~ $ dpkg -l | grep libcamera
ii  libcamera0:arm64      0.3.2+rpt20240927-1   arm64   complex camera support library
ii  libcamera-apps       1.5.1-1               arm64   libcamera-apps
pi@raspberrypi:~ $
So libcamera looks like it’s installed. Now running the second command - it’s taking a bit. I’ll paste the bug.txt once it finishes.
Perfect, that’s exactly what I needed for the first part - libcamera0 and libcamera-apps are both present and the versions look reasonable, so we can probably rule out a totally missing driver stack. Now the second command is the important one.
When it’s done, open the resulting bug.txt and send it over. That report will show whether the Pi is even seeing anything on the CSI port and how libcamera is enumerating the cameras. That’s what tells us if it’s a detection/config problem vs. a genuinely faulty module.
Here’s the bug.txt output. I’m not going to pretend I understand all of it, but here it is:
# camera-bug-report
Kernel: 6.6.51+rpt-rpi-v8
libcamera0: 0.3.2+rpt20240927-1
libcamera-apps: 1.5.1-1
[0:00:00.000000000] [1234]  INFO Camera camera_manager.cpp:299 libcamera v0.3.2+rpt20240927
$ cat /boot/firmware/config.txt | grep -i camera
(no camera-related overlay lines found)
$ ls /dev/video*
ls: cannot access '/dev/video*': No such file or directory
$ dmesg | grep -i -E "camera|ov64|imx"
(no matching lines)
So yeah - “no cameras available” and it doesn’t even look like /dev/video* exists. That’s what I’ve been getting the whole time.
That’s a really useful report, thank you. A few things stand out:
  • libcamera initializes fine, so the library itself is working.
  • It reports no cameras available and there are no /dev/video* devices and no camera/OV64/IMX entries in dmesg.
  • Importantly, there are no camera overlay lines picked up in config.txt in that check.
That combination usually points to the camera overlay/config not being enabled or not matching the module, rather than a dead sensor - though I can’t fully confirm that until we check the config side.
Can you do two things?
  1. Show me the full [all]/dtoverlay section of /boot/firmware/config.txt (just the camera-related parts).
  2. Confirm the exact dtoverlay= line your 64MP-AF instructions told you to use.
Also, since the ribbon orientation was set by hand, let me ask: are the contacts facing the correct direction on both the Pi and the camera end? Different ends of the cable can catch people out.
Here’s the relevant part of config.txt:
dtoverlay=vc4-kms-v3d
camera_auto_detect=1
#dtoverlay=arducam-64mp
Interesting - the arducam overlay line is there but it’s commented out with a #. The instructions I followed had camera_auto_detect=1 so I left it as-is. Should that arducam line be active instead?
On the ribbon: yes, contacts are facing the correct way on both ends, and I reseated it just to be sure. Same result after reseating.
That explains a lot. With camera_auto_detect=1 the Pi tries to identify the sensor automatically, and for a number of the Arducam modules (especially on older boards like the Pi 3 B+) you need the explicit dtoverlay for that module enabled instead, because auto-detect won’t pick it up.
Before you change anything, keep the bug.txt you already generated - that’s our “before” state and it’s useful. Now, let’s try switching to the explicit overlay:
  1. Comment out camera_auto_detect=1 (put a # in front).
  2. Uncomment the arducam line so it reads dtoverlay=arducam-64mp (use the exact overlay name from your module’s instructions).
  3. Save and reboot.
  4. After reboot, run the capture again: libcamera-still -t 1000 -o test.jpg
Tell me what happens.
OK I made those changes and rebooted. Now libcamera-still gives:
[0:00:00.123456789] [5678]  INFO Camera camera_manager.cpp:299 libcamera v0.3.2+rpt20240927
Still “no cameras available.” And dmesg still shows nothing about a camera. So enabling the overlay didn’t help. At this point I’m pretty convinced it’s a hardware fault.
Good - that’s a meaningful result even though it’s not the one we wanted. We now know the software stack is fine (libcamera initializes, packages are installed) and the explicit overlay still yields no cameras available with nothing appearing in dmesg or /dev/video*.
Since you’ve already confirmed the ribbon orientation twice and reseated it, let’s generate a fresh bug report now with the overlay active so the state is captured:
camera-bug-report -t 5 -o bug2.txt -c "libcamera-still -t 1000 -o test.jpg"
Please send me both bug files - the original bug.txt (before the overlay change) and this new bug2.txt (with the overlay enabled). Having the before/after pair lets me compare them and see whether the Pi is registering any camera interface at all. If neither shows any CSI detection, that supports what you’re suspecting, but I want the data before we call it.
Fair enough. Here’s bug2.txt with the overlay enabled:
# camera-bug-report
dtoverlay=arducam-64mp (enabled)
camera_auto_detect=0
$ ls /dev/video*
$ dmesg | grep -i -E "camera|ov64|imx|i2c"
(no matching lines)
$ vcgencmd get_camera
supported=0 detected=0
vcgencmd get_camera shows detected=0. So it’s not detecting anything at the hardware level either, correct?
That’s correct, and you’ve done a solid job narrowing it down. To summarize where we are:
  • libcamera and libcamera-apps are installed and the library initializes fine, so the driver stack is intact.
  • Both the auto-detect config and the explicit dtoverlay=arducam-64mp config result in no cameras available.
  • No /dev/video* devices, no camera/OV64/IMX entries in dmesg, and vcgencmd get_camera reports detected=0 with the overlay enabled.
  • Ribbon orientation has been verified and reseated.
So the software side is ruled out and the Pi isn’t registering anything on the camera interface even with the correct overlay. That points to the module not being detected at the hardware level. I’ve got your before/after bug reports here.
Based on all this, I’ve sent you the next-step details through private message - please check your inbox so we can move forward from here. Keep the bug.txt and bug2.txt around just in case.
