Ordered it via a Dutch reseller -
X003B4R0NX -
Raspberry Pi 5 -
Quick Start - Arducam Wiki -
When usinglibcamera--hello
I get the following output
[0:02:01.556345165] [2011] INFO Camera camera_manager.cpp:284 libcamera v0.2.0+120-eb00c13d
[0:02:01.564812567] [2014] INFO RPI pisp.cpp:695 libpisp version v1.0.5 999da5acb4f4 17-04-2024 (14:29:29)
[0:02:01.565848186] [2014] WARN CameraSensorProperties camera_sensor_properties.cpp:274 No static properties available for 'arducam_64mp'
[0:02:01.565868962] [2014] WARN CameraSensorProperties camera_sensor_properties.cpp:276 Please consider updating the camera sensor properties database
[0:02:01.577665374] [2014] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam_64mp.json' not found for IPA module 'rpi/pisp'
[0:02:01.577723077] [2014] ERROR IPARPI ipa_base.cpp:124 Could not create camera helper for arducam_64mp
[0:02:01.577737248] [2014] ERROR RPI pipeline_base.cpp:796 Failed to load a suitable IPA library
[0:02:01.577746887] [2014] ERROR RPI pisp.cpp:922 Failed to register camera arducam_64mp 4-001a: -22
Preview window unavailable
dmesg | grep arducam
[ 3.720687] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 3.749931] arducam_64mp 4-001a: Device found Arducam 64MP.
[ 3.754956] rp1-cfe 1f00128000.csi: Using sensor arducam_64mp 4-001a for capture
Also when running the install scripts I get this:
libcamera-dev : Depends: libcamera0.2 (= 0.2.0+rpt20240227-1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
libcamera-ipa : Depends: libcamera0.2 (>= 0.2.0+rpt20240418) but 0.2.0+rpt20240227-1 is to be installed
Following command libcamera–list
No cameras available!
- Purging libcamera and fresh install
- What help do you need?
I need to get the camera to work.
