Made X/EGL preview window
[0:08:42.687230909] [4714] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3729-5f595cca
[0:08:42.695200050] [4751] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam_64mp'
[0:08:42.695247036] [4751] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:08:42.732160240] [4751] WARN RPI raspberrypi.cpp:1274 Mismatch between Unicam and CamHelper for embedded data usage!
[0:08:42.732670102] [4751] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:08:42.733056594] [4751] INFO RPI raspberrypi.cpp:1398 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media1
[0:08:42.733841038] [4714] INFO Camera camera.cpp:1029 configuring streams: (0) 2312x1736-YUV420
[0:08:42.734276497] [4751] INFO RPI raspberrypi.cpp:763 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 2312x1736-SBGGR10_1X10 - Selected unicam format: 2312x1736-pBAA
terminate called after throwing an instance of 'std::runtime_error'
what(): failed to import fd 21
Aborted
I can hear the sound of autofocus module but it doesn’t work.
Then I try:
I don’t see a problem. Generally speaking, fd21 is a problem of gpu memory allocation, but it has already taken effect there. I now suspect it is the display problem.
pi@raspberrypi:~ $ libcamera-still -t 5000 -n -o test.jpg
[0:29:49.508326108] [6082] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3729-5f595cca
[0:29:49.514331747] [6084] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam_64mp'
[0:29:49.514378785] [6084] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:29:49.541543628] [6084] WARN RPI raspberrypi.cpp:1274 Mismatch between Unicam and CamHelper for embedded data usage!
[0:29:49.542139984] [6084] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:29:49.542431024] [6084] INFO RPI raspberrypi.cpp:1398 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media1 and ISP device /dev/media3
[0:29:49.543457939] [6082] INFO Camera camera.cpp:1029 configuring streams: (0) 4624x3472-YUV420
[0:29:49.544504966] [6084] INFO RPI raspberrypi.cpp:763 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[0:29:55.032591906] [6082] INFO Camera camera.cpp:1029 configuring streams: (0) 9152x6944-YUV420 (1) 9152x6944-SBGGR10_CSI2P
[0:29:55.039677704] [6084] INFO RPI raspberrypi.cpp:763 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 9152x6944-SBGGR10_1X10 - Selected unicam format: 9152x6944-pBAA
Still capture image received
This is to make sure the camera is normal, now it is certain that there is a problem with the display, are you using the display, or a remote connection
