B0397 -
Jetson Orin NX 16Gb and rPI4 -
https://docs.arducam.com/Nvidia-Jetson-Camera/Multi-Camera-CamArray/quick-start/
- Problems you were having?
Difference in image quality of the same HAT on pi4 and jetson
Tried to experiment with ISP file on Jetson but it didn’t help
- What help do you need?
I have Arducam 12MP*4 477P Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA. Firstly I used it on Jetson but the image quality does not look good. I used ISP from arducam, but quality with it is even worse than the default. I removed AWB from ISP config file and it started looks good enough.
Then I’ve experimented with rPI4 by connecting the same HAT to it and noticed that the image quality is much better. I didn’t do any specific changes, use default manuals and has huge difference. I need help with this problem, I want my Jetson to process images from cameras that have the same quality as I can get on Pi4.
