Cable connections are good because I tried the same setup with Tegra Release R32 4.3 and I can display the video but with a lot of frames dropped.
To summarize the problem:
Here there is the complete boot log for Tegra Release R32 4.3:
nx@nx-xaviernxkit:~$ dmesg
[ 0.000000] Linux version 4.9.140-tegra (wong@wong-HP-Z420-Workstation) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #6 SMP PREEMPT Wed Jul 29 13:23:38 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2032640
[ 0.000000] DMA zone: 7184 pages used for memmap
[ 0.000000] DMA zone: 459776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd0b000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2000880
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29100(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190352K/8130560K available (15294K kernel code, 2938K rwdata, 6736K rodata, 8576K init, 609K bss, 186544K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14e808 ( 2939 KB)
[ 0.000000] .bss : 0xffffff800a14e808 - 0xffffff800a1e6f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000605] Console: colour dummy device 80x25
[ 0.000616] console [tty0] enabled
[ 0.000624] bootconsole [tegra_comb_uart0] disabled
[ 0.000638] kmemleak: Kernel memory leak detector disabled
[ 0.000657] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000672] pid_max: default: 32768 minimum: 301
[ 0.001748] Security Framework initialized
[ 0.002316] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002327] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.003942] ftrace: allocating 47143 entries in 185 pages
[ 0.401491] sched-energy: Sched-energy-costs installed from DT
[ 0.401511] ASID allocator initialised with 65536 entries
[ 0.435725] tegra-id: chipid=21917.
[ 0.435737] tegra-id: opt_subrevision=1.
[ 0.435764] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.435778] DTS File Name: /home/wang/Arducam/Jetson/l4t-32.4.3-NX/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.435788] DTB Build time: Sep 24 2020 17:09:45
[ 0.484168] CPU1: Booted secondary processor [4e0f0040]
[ 0.516213] CPU2: Booted secondary processor [4e0f0040]
[ 0.548276] CPU3: Booted secondary processor [4e0f0040]
[ 0.580548] CPU4: Booted secondary processor [4e0f0040]
[ 0.612654] CPU5: Booted secondary processor [4e0f0040]
[ 0.612861] Brought up 6 CPUs
[ 0.612871] SMP: Total of 6 processors activated.
[ 0.612880] CPU features: detected feature: Privileged Access Never
[ 0.612887] CPU features: detected feature: LSE atomic instructions
[ 0.612893] CPU features: detected feature: User Access Override
[ 0.612899] CPU features: detected feature: 32-bit EL0 Support
[ 0.614328] CPU: All CPU(s) started at EL2
[ 0.614392] alternatives: patching kernel code
[ 0.620829] devtmpfs: initialized
[ 0.656465] Initilizing CustomIPI irq domain
[ 0.656684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.656700] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.666559] pinctrl core: initialized pinctrl subsystem
[ 0.666801] OS set in device tree is not L4T.
[ 0.667009] regulator-dummy: no parameters
[ 0.667219] Initializing plugin-manager
[ 0.667275] Plugin module not found
[ 0.667320] Plugin-manager status disabled
[ 0.668327] NET: Registered protocol family 16
[ 0.669552] pstore: using zlib compression
[ 0.669583] console [pstore-1] enabled
[ 0.669591] pstore: Registered ramoops as persistent store backend
[ 0.669600] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.683250] cpuidle: using governor menu
[ 0.684146] bpmp: waiting for handshake
[ 0.684157] bpmp: handshake completed
[ 0.684174] bpmp: synchronizing channels
[ 0.684185] bpmp: channels synchronized
[ 0.684195] bpmp: mail init ok
[ 0.686559] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.686730] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.686736] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.686743] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.686749] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.686755] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.686764] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.686772] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.686778] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.686785] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.686791] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.689562] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.689593] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.692224] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.692969] tegra_aon_clk_init: ok
[ 0.692987] Registering BPMP clocks…
[ 0.693112] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.693731] Serial: AMBA PL011 UART driver
[ 0.693886] tegra_powergate_init: DONE
[ 0.693976] DTS File Name: /home/wang/Arducam/Jetson/l4t-32.4.3-NX/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.693992] DTB Build time: Sep 24 2020 17:09:45
[ 0.696431] Tegra reboot handler registered.
[ 0.703166] iommu: Adding device 14160000.pcie to group 0
[ 0.703786] iommu: Adding device 141a0000.pcie to group 1
[ 0.704983] iommu: Adding device 2490000.ether_qos to group 2
[ 0.705402] iommu: Adding device 3100000.serial to group 3
[ 0.705845] iommu: Adding device 3110000.serial to group 4
[ 0.706162] iommu: Adding device 3140000.serial to group 5
[ 0.706674] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.706802] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.706825] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.706848] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.706857] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.706905] tegra-pmc: PMC Prod config success
[ 0.707076] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.707089] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.707408] iommu: Adding device 3400000.sdhci to group 6
[ 0.707832] iommu: Adding device 3210000.spi to group 7
[ 0.708184] iommu: Adding device 3230000.spi to group 8
[ 0.708493] iommu: Adding device 3270000.spi to group 9
[ 0.709379] iommu: Adding device 3160000.i2c to group 10
[ 0.709726] iommu: Adding device c240000.i2c to group 11
[ 0.710050] iommu: Adding device 3180000.i2c to group 12
[ 0.710367] iommu: Adding device 3190000.i2c to group 13
[ 0.710791] iommu: Adding device 31b0000.i2c to group 14
[ 0.711100] iommu: Adding device 31c0000.i2c to group 15
[ 0.711487] iommu: Adding device c250000.i2c to group 16
[ 0.711828] iommu: Adding device 31e0000.i2c to group 17
[ 0.712306] iommu: Adding device sound to group 18
[ 0.712722] iommu: Adding device 3510000.hda to group 19
[ 0.713184] iommu: Adding device bc00000.rtcpu to group 20
[ 0.714826] iommu: Adding device 13e10000.host1x to group 21
[ 0.715209] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.715549] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.715863] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.716169] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.716515] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.716819] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.717150] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.717470] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.717934] iommu: Adding device 15340000.vic to group 30
[ 0.718303] iommu: Adding device 15380000.nvjpg to group 31
[ 0.718529] iommu: Adding device 15500000.tsec to group 32
[ 0.718752] iommu: Adding device 15100000.tsecb to group 33
[ 0.718981] iommu: Adding device 15480000.nvdec to group 34
[ 0.719220] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.719483] iommu: Adding device 154c0000.nvenc to group 36
[ 0.719745] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.720104] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.720454] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.720963] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.725047] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.725122] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.725904] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.725952] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.727502] iommu: Adding device 15c10000.vi to group 42
[ 0.727659] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.728024] iommu: Adding device 14800000.isp to group 43
[ 0.728873] iommu: Adding device 16000000.pva0 to group 44
[ 0.729357] iommu: Adding device 16800000.pva1 to group 45
[ 0.729705] iommu: Adding device 15810000.se to group 46
[ 0.730049] iommu: Adding device 15820000.se to group 47
[ 0.730290] iommu: Adding device 15830000.se to group 48
[ 0.730539] iommu: Adding device 15840000.se to group 49
[ 0.730801] iommu: Adding device c1a0000.aon to group 50
[ 0.732327] iommu: Adding device d000000.bpmp to group 51
[ 0.732666] bpmp: ping status is 0
[ 0.732790] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.736263] bpmp d000000.bpmp: probe ok
[ 0.737589] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.738054] iommu: Adding device smmu_test to group 52
[ 0.739033] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c10000
[ 0.739052] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c20000
[ 0.739095] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c30000
[ 0.739112] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c40000
[ 0.739129] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c50000
[ 0.739145] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b80000
[ 0.739180] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b90000
[ 0.739195] mc: mapped MMIO address: 0xffffff800b070000 → 0x2ba0000
[ 0.739210] mc: mapped MMIO address: 0xffffff800b090000 → 0x2bb0000
[ 0.739225] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1700000
[ 0.739241] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1710000
[ 0.739256] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1720000
[ 0.739270] mc: mapped MMIO address: 0xffffff800b110000 → 0x1730000
[ 0.739285] mc: mapped MMIO address: 0xffffff800b130000 → 0x1740000
[ 0.739300] mc: mapped MMIO address: 0xffffff800b150000 → 0x1750000
[ 0.739315] mc: mapped MMIO address: 0xffffff800b170000 → 0x1760000
[ 0.739329] mc: mapped MMIO address: 0xffffff800b190000 → 0x1770000
[ 0.739398] mc-err: mcerr ops are set to t19x
[ 0.744499] iommu: Adding device 2600000.dma to group 53
[ 0.749146] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.750258] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.750293] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.750326] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.750611] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.756649] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.756751] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.756788] GPIO line 266 (w-disable1) hogged as output/high
[ 0.756819] GPIO line 264 (w-disable2) hogged as output/high
[ 0.757075] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.758794] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.758805] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.759428] iommu: Adding device 3550000.xudc to group 54
[ 0.759984] iommu: Adding device 3610000.xhci to group 55
[ 0.761834] arm64_ras arm64_ras: probed
[ 0.762192] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.762244] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.762320] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.762396] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.762470] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.762536] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.762712] carmel_ras_enable: RAS enabled on cpu0
[ 0.762883] carmel_ras_enable: RAS enabled on cpu1
[ 0.763086] carmel_ras_enable: RAS enabled on cpu2
[ 0.763286] carmel_ras_enable: RAS enabled on cpu3
[ 0.763490] carmel_ras_enable: RAS enabled on cpu4
[ 0.763716] carmel_ras_enable: RAS enabled on cpu5
[ 0.763788] carmel_ras carmel_ras: probed
[ 0.764724] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.765200] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.765888] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.766535] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.767192] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.767532] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.768647] vdd-ac-bat: 5000 mV
[ 0.769103] vdd-sdmmc1-sw: 3300 mV
[ 0.769381] vdd-1v8-sd: 1800 mV
[ 0.769640] vdd-3v3-cvb: 3300 mV
[ 0.769933] vdd-1v8-cvb: 1800 mV
[ 0.770237] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.770271] vdd-epb-1v0: 1000 mV
[ 0.770573] avdd-cam-2v8: 2800 mV
[ 0.770832] vdd-fan: 5000 mV
[ 0.771063] vdd-hdmi-5v0: 5000 mV
[ 0.771325] vdd_sys_en: 1200 mV
[ 0.805650] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.811708] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.812012] SCSI subsystem initialized
[ 0.812272] libata version 3.00 loaded.
[ 0.812444] usbcore: registered new interface driver usbfs
[ 0.812499] usbcore: registered new interface driver hub
[ 0.812586] usbcore: registered new device driver usb
[ 0.823567] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.826420] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.833293] vdd-1v0: at 1000 mV
[ 0.837303] vdd-1v8-hs: at 1800 mV
[ 0.841329] vdd-1v8-ls: at 1800 mV
[ 0.845379] vdd-1v8-ao: at 1800 mV
[ 0.849378] vddio-ddr-1v1: at 1100 mV
[ 0.853153] vdd-rtc: at 800 mV
[ 0.854174] spmic-ldo1: at 2375 mV
[ 0.861209] vdd-ao-3v3: at 3300 mV
[ 0.869240] vddio-emmc-3v3: at 3300 mV
[ 0.870335] spmic-ldo4: at 1587 mV
[ 0.877278] vdd-usb-3v3: at 3300 mV
[ 0.885319] vddio-sdmmc1-3v3: at 3300 mV
[ 0.889340] vdd-csi-1v2: at 1200 mV
[ 0.890272] spmic-ldo8: at 1800 mV
[ 0.894201] GPIO line 246 (gpio_default) hogged as output/high
[ 0.895138] GPIO line 247 (gpio_default) hogged as output/high
[ 0.895436] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.895666] max77620 4-003c: max77620 probe successful
[ 0.896116] media: Linux media interface: v0.10
[ 0.896157] Linux video capture interface: v2.00
[ 0.897411] pps_core: LinuxPPS API ver. 1 registered
[ 0.897417] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.897434] PTP clock support registered
[ 0.897608] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.897909] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.897940] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.900382] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[ 0.900441] trusty trusty: selected api version: 3 (requested 3)
[ 0.901448] Advanced Linux Sound Architecture Driver Initialized.
[ 0.902069] Bluetooth: Core ver 2.22
[ 0.902148] NET: Registered protocol family 31
[ 0.902155] Bluetooth: HCI device and connection manager initialized
[ 0.902165] Bluetooth: HCI socket layer initialized
[ 0.902174] Bluetooth: L2CAP socket layer initialized
[ 0.902198] Bluetooth: SCO socket layer initialized
[ 0.904898] camchar: rtcpu character device driver loaded
[ 0.905338] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.905424] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.906157] clocksource: Switched to clocksource arch_sys_counter
[ 0.948281] VFS: Disk quotas dquot_6.6.0
[ 0.948408] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.948697] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.950454] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.950513] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.950789] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.950798] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.950831] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.950839] nvmap_page_pool_init: Total RAM pages: 1986004
[ 0.950846] nvmap_page_pool_init: nvmap page pool size: 248250 pages (969 MB)
[ 0.951218] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.951485] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.952347] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.964578] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.964743] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.964908] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.965053] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.965205] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.966445] la/ptsa driver initialized.
[ 0.966855] NET: Registered protocol family 2
[ 0.967721] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.968048] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.968664] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.968708] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.968825] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.969258] NET: Registered protocol family 1
[ 0.969871] RPC: Registered named UNIX socket transport module.
[ 0.969877] RPC: Registered udp transport module.
[ 0.969883] RPC: Registered tcp transport module.
[ 0.969888] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.969899] PCI: CLS 0 bytes, default 64
[ 0.970218] Trying to unpack rootfs image as initramfs…
[ 1.145141] Freeing initrd memory: 5432K
[ 1.162740] host1x 13e10000.host1x: initialized
[ 1.164474] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.169042] audit: initializing netlink subsys (disabled)
[ 1.169092] audit: type=2000 audit(0.792:1): initialized
[ 1.169787] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.176914] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.182076] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.182636] 9p: Installing v9fs 9p2000 file system support
[ 1.187271] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.187419] io scheduler noop registered
[ 1.187593] io scheduler cfq registered (default)
[ 1.191139] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.194421] iommu: Adding device 2993000.adsp to group 56
[ 1.199197] random: fast init done
[ 1.267417] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.268346] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.280753] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.281244] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.281808] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.282256] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.282805] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.285282] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.285479] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.288065] tsec 15500000.tsec: initialized
[ 1.289718] tsec 15100000.tsecb: initialized
[ 1.293259] nvdec 15480000.nvdec: initialized
[ 1.295705] nvdec 15140000.nvdec1: initialized
[ 1.300605] falcon 15340000.vic: initialized
[ 1.302408] falcon 15380000.nvjpg: initialized
[ 1.304187] falcon 154c0000.nvenc: initialized
[ 1.306280] falcon 15a80000.nvenc1: initialized
[ 1.309387] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.311643] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.313113] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.314569] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.316045] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.317634] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.319249] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.320715] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.324610] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.330028] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.330416] scare-pigeon 14b00000.isp-thi: initialized
[ 1.336286] pva 16000000.pva0: initialized
[ 1.342288] pva 16800000.pva1: initialized
[ 1.347573] nvdla 15880000.nvdla0: initialized
[ 1.352180] nvdla 158c0000.nvdla1: initialized
[ 1.353260] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.353275] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.353307] tegradccommon 15200000.dc_common: dma mapping done
[ 1.353581] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.353593] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.353908] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.353932] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.354226] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.354235] tegra_cec 3960000.tegra_cec: probed
[ 1.354702] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.354729] generic_infoframe_type: 0x87
[ 1.354814] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.354857] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[ 1.359218] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.359226] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.359232] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.359430] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.359470] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.362285] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.362294] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.364675] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.365372] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.365382] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.365670] kfuse 3830000.kfuse: initialized
[ 1.366369] tegradc 15200000.nvdisplay: probed
[ 1.366946] Console: switching to colour frame buffer device 80x30
[ 1.366974] tegradc 15200000.nvdisplay: fb registered
[ 1.367189] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.367669] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.367710] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.367785] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.367818] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.368003] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.368014] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.375760] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.377611] tegradc 15210000.nvdisplay: probed
[ 1.377838] tegradc 15210000.nvdisplay: fb registered
[ 1.377883] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.379012] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.379749] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.380683] console [ttyTCU0] enabled
[ 1.380921] [drm] Initialized
[ 1.381376] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.381386] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.381398] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.381412] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.381427] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.381432] Extcon DP: HPD disabled
[ 1.381437] hpd: hpd_switch 0
[ 1.381443] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.381454] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.381463] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.407265] brd: module loaded
[ 1.428158] loop: module loaded
[ 1.428234] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.428367] tegra_profiler: auth: init
[ 1.428895] THERMAL EST: found 3 subdevs
[ 1.428902] THERMAL EST num_resources: 0
[ 1.428908] [THERMAL EST subdev 0]
[ 1.428914] [THERMAL EST subdev 1]
[ 1.428919] [THERMAL EST subdev 2]
[ 1.428928] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.429227] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.429232] THERMAL EST: thz register success.
[ 1.433424] THERMAL EST: end of probe, return err: 0
[ 1.433982] sd: No Scsi addr parsed to reserve index
[ 1.434010] hisi_sas: driver version v1.6
[ 1.442837] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.442877] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.442887] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.443195] 1 ofpart partitions found on MTD device spi6.0
[ 1.443201] Creating 1 MTD partitions on “spi6.0”:
[ 1.443220] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.448938] libphy: Fixed MDIO Bus: probed
[ 1.449407] tun: Universal TUN/TAP device driver, 1.6
[ 1.449412] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.450838] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.450844] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.450914] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.450919] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.450957] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.450961] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.451021] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.451027] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.705572] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 15 de d3
[ 1.705682] libphy: dwc_phy: probed
[ 1.707483] PPP generic driver version 2.4.2
[ 1.707630] PPP BSD Compression module registered
[ 1.707636] PPP Deflate Compression module registered
[ 1.707655] PPP MPPE Compression module registered
[ 1.707662] NET: Registered protocol family 24
[ 1.707700] usbcore: registered new interface driver r8152
[ 1.707729] usbcore: registered new interface driver asix
[ 1.707755] usbcore: registered new interface driver ax88179_178a
[ 1.707779] usbcore: registered new interface driver cdc_ether
[ 1.707801] usbcore: registered new interface driver net1080
[ 1.707824] usbcore: registered new interface driver cdc_subset
[ 1.707849] usbcore: registered new interface driver zaurus
[ 1.707881] usbcore: registered new interface driver cdc_ncm
[ 1.708004] VFIO - User Level meta-driver version: 0.3
[ 1.709495] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.709514] ehci-pci: EHCI PCI platform driver
[ 1.709542] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.709562] ohci-pci: OHCI PCI platform driver
[ 1.709592] ohci-platform: OHCI generic platform driver
[ 1.713840] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.715694] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f5250800 id
[ 1.715893] usbcore: registered new interface driver uas
[ 1.715931] usbcore: registered new interface driver usb-storage
[ 1.716067] usbcore: registered new interface driver usbserial
[ 1.718176] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.718212] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.718231] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.718930] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.718997] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.719243] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.719251] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.719258] usb usb1: Product: xHCI Host Controller
[ 1.719264] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.719270] usb usb1: SerialNumber: 3610000.xhci
[ 1.719707] hub 1-0:1.0: USB hub found
[ 1.719753] hub 1-0:1.0: 4 ports detected
[ 1.720206] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.720243] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.720258] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.720507] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.720536] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.720543] usb usb2: Product: xHCI Host Controller
[ 1.720549] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.720555] usb usb2: SerialNumber: 3610000.xhci
[ 1.721241] hub 2-0:1.0: USB hub found
[ 1.721283] hub 2-0:1.0: 4 ports detected
[ 1.721823] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.721889] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.722642] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.722652] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.722682] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.722909] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.723438] mousedev: PS/2 mouse device common for all mice
[ 1.723536] usbcore: registered new interface driver xpad
[ 1.855787] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.857181] Wake73 for irq=42
[ 1.858468] rtc rtc1: alarm rtc device
[ 1.858485] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.858520] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.858692] i2c /dev entries driver
[ 1.860502] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.860873] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.860882] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.861056] arducam-csi2: chip found @ 0x18 (i2c-2-mux (chan_id 0))
[ 1.884981] arducam-csi2: arducam_read: 0x103 0x0030
[ 1.885252] arducam-csi2: arducam_read: 0x101 0x0003
[ 1.885262] arducam-csi2 9-000c: firmware version: 3
[ 1.885526] arducam-csi2: arducam_read: 0x102 0x0000
[ 1.885532] arducam-csi2 9-000c: Sensor ID: 0x0000
[ 1.886540] arducam-csi2: arducam_read: 0x201 0x002a
[ 1.887545] arducam-csi2: arducam_read: 0x201 0xfffffffe
[ 1.889288] arducam-csi2: arducam_read: 0x201 0x002a
[ 1.889579] arducam-csi2: arducam_read: 0x203 0x0002
[ 1.889839] arducam-csi2: arducam_read: 0x202 0x0004
[ 1.890868] arducam-csi2: arducam_read: 0x301 0x1400
[ 1.891869] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.893633] arducam-csi2: arducam_read: 0x301 0x1400
[ 1.893895] arducam-csi2: arducam_read: 0x302 0x0320
[ 1.894916] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.895176] arducam-csi2: arducam_read: 0x302 0xfffffffe
[ 1.896910] arducam-csi2: arducam_read: 0x201 0xfffffffe
[ 1.898691] arducam-csi2: arducam_read: 0x401 0x980911
[ 1.899755] arducam-csi2: arducam_read: 0x401 0x980913
[ 1.900815] arducam-csi2: arducam_read: 0x401 0x981901
[ 1.901832] arducam-csi2: arducam_read: 0x401 0xfffffffe
[ 1.903610] arducam-csi2: arducam_read: 0x401 0x980911
[ 1.903876] arducam-csi2: arducam_read: 0x403 0xffff
[ 1.904153] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.904431] arducam-csi2: arducam_read: 0x405 0x02a9
[ 1.904707] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.905749] arducam-csi2: arducam_read: 0x401 0x980913
[ 1.906025] arducam-csi2: arducam_read: 0x403 0x000f
[ 1.906342] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.906623] arducam-csi2: arducam_read: 0x405 0x0001
[ 1.906900] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.907943] arducam-csi2: arducam_read: 0x401 0x981901
[ 1.908221] arducam-csi2: arducam_read: 0x403 0x0001
[ 1.908497] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.908773] arducam-csi2: arducam_read: 0x405 0x0000
[ 1.909049] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.909059] arducam-csi2: arducam_enum_controls: new custom ctrl, ctrl: ffffffc1f5a38900.
[ 1.910092] arducam-csi2: arducam_read: 0x401 0xfffffffe
[ 1.910404] arducam-csi2: arducam_read: 0x403 0x0000
[ 1.910682] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.910959] arducam-csi2: arducam_read: 0x405 0x0000
[ 1.911235] arducam-csi2: arducam_read: 0x404 0x0000
[ 1.911247] arducam-csi2: arducam_s_ctrl: cid = (0x980911), value = (681).
[ 1.912778] arducam-csi2: arducam_s_ctrl: cid = (0x980913), value = (1).
[ 1.914300] arducam-csi2: arducam_s_ctrl: cid = (0x981901), value = (0).
[ 1.915819] arducam-csi2: arducam_s_ctrl: cid = (0x981902), value = (0).
[ 1.915826] arducam-csi2: arducam_s_ctrl: cid = (0x981903), value = (2000).
[ 1.916592] arducam-csi2 9-000c: sensor arducam-csi2 9-000c registered
[ 1.916667] arducam-csi2: chip found @ 0x18 (i2c-2-mux (chan_id 1))
[ 1.940139] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.940349] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.940499] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.940586] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 1.940769] arducam-csi2 10-000c: probe failed
[ 1.940900] arducam-csi2 10-000c: Failed to setup board.
[ 1.942289] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.948641] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 1.952773] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 1.952807] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 1.952813] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 1.952899] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 1.952965] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 1.952971] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 1.953232] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 1.953283] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 1.953291] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 1.953634] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 1.953722] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 1.953734] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 1.954220] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 1.954277] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 1.954285] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 1.954569] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 1.955006] FAN dev name: pwm-fan
[ 1.955048] FAN:gpio request success.
[ 1.955057] FAN: can’t find tach_gpio
[ 1.955068] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.955101] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 1.955317] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.955324] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.955955] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.955963] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 1.955970] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 1.955979] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 1.955985] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.955991] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.955998] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.956004] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.956011] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.956018] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.956968] device-mapper: uevent: version 1.0.3
[ 1.957416] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 1.960821] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.961787] cpuidle: Initializing cpuidle driver
[ 1.962504] sdhci: Secure Digital Host Controller Interface driver
[ 1.962507] sdhci: Copyright(c) Pierre Ossman
[ 1.962511] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.962723] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.963714] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.965581] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 1.969384] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.971013] tegra-se-nvhost 15810000.se: initialized
[ 1.972175] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.973151] tegra-se-nvhost 15820000.se: initialized
[ 1.974428] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.975641] tegra-se-nvhost 15830000.se: initialized
[ 1.976377] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.977297] tegra-se-nvhost 15840000.se: initialized
[ 1.978174] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.978385] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.979518] usbcore: registered new interface driver usbhid
[ 1.979523] usbhid: USB HID core driver
[ 1.983707] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 1.984708] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.985058] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.985627] denver_knobs_init:MTS_VERSION:50168445
[ 1.985769] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 1.986546] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.986897] t19x_cache tegra-cache: probed
[ 1.989206] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 1.989216] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 1.989803] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 1.990157] PLL_AON clock registered
[ 1.991464] Clocks initialized successfully
[ 1.992966] nvpmodel: initialized successfully
[ 1.994088] trusty-virtio trusty:virtio: initializing
[ 1.994380] trusty_ipc virtio0: vring0: va¶ ffffffc1f4d18000(0) qsz 32 notifyid 1
[ 1.994391] trusty_ipc virtio0: vring1: va¶ ffffffc1f4d1a000(0) qsz 32 notifyid 2
[ 1.994530] trusty-virtio trusty:virtio: initializing done
[ 1.994679] trusty_ipc virtio0: is online
[ 1.995571] tegra-hda 3510000.hda: Override SDO lines to 4
[ 1.995926] usbcore: registered new interface driver snd-usb-audio
[ 2.008473] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.008691] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.008915] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.009166] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.014244] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.014300] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.046148] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.085188] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.085197] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.085202] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.085207] usb 1-2: Manufacturer: Generic
[ 2.086461] hub 1-2:1.0: USB hub found
[ 2.088060] hub 1-2:1.0: 4 ports detected
[ 2.111595] OPE platform probe
[ 2.111727] OPE platform probe successful
[ 2.133819] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.195656] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.195769] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.195860] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.195959] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.196055] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.196186] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.196281] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.196401] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.196530] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.196661] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.196770] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.196865] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.196957] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.197061] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.197160] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.197253] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.197384] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.197518] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.197599] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.197677] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.214146] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.225061] u32 classifier
[ 2.225067] Actions configured
[ 2.225139] Initializing XFRM netlink socket
[ 2.225670] NET: Registered protocol family 10
[ 2.226444] NET: Registered protocol family 17
[ 2.226458] NET: Registered protocol family 15
[ 2.226517] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.226614] Bluetooth: RFCOMM socket layer initialized
[ 2.226631] Bluetooth: RFCOMM ver 1.11
[ 2.226639] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.226655] Bluetooth: HIDP socket layer initialized
[ 2.226691] 9pnet: Installing 9P2000 support
[ 2.226728] Key type dns_resolver registered
[ 2.227252] Registered cp15_barrier emulation handler
[ 2.227272] Registered setend emulation handler
[ 2.228972] registered taskstats version 1
[ 2.229443] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.230554] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.230572] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.230581] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.230586] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.235278] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.235286] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.235291] usb 1-3: Product: Bluetooth Radio
[ 2.235295] usb 1-3: Manufacturer: Realtek
[ 2.235299] usb 1-3: SerialNumber: 00e04c000001
[ 2.272604] mmc0: hw tuning done …
[ 2.272636] mmc0: new ultra high speed SDR104 SDHC card at address 5048
[ 2.273017] mmcblk0: mmc0:5048 SD32G 28.9 GiB
[ 2.274890] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.338182] tegra-pcie-dw 14160000.pcie: link is up
[ 2.338360] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.338366] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.338374] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.338380] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.338384] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.338412] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.338574] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.338787] iommu: Adding device 0004:00:00.0 to group 58
[ 2.339069] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.339207] pci 0004:01:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 2.339409] pci 0004:01:00.0: reg 0x18: [mem 0x1740000000-0x174000ffff 64bit]
[ 2.340189] pci 0004:01:00.0: supports D1 D2
[ 2.340194] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.340496] iommu: Adding device 0004:01:00.0 to group 59
[ 2.351118] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.351125] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.351132] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.351215] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.351243] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.351248] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.351256] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.351275] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.351351] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.351559] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.351564] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.351571] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.351661] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.352217] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.353116] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.353130] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.353137] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.353159] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.358165] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 2.358171] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.462190] tegra-pcie-dw 141a0000.pcie: link is up
[ 2.462444] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.462468] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.462476] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.462482] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.462487] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.462512] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.462652] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.462821] iommu: Adding device 0005:00:00.0 to group 60
[ 2.463214] pci 0005:01:00.0: [144d:a808] type 00 class 0x010802
[ 2.463326] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.464238] iommu: Adding device 0005:01:00.0 to group 61
[ 2.474980] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 2.474989] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 2.475048] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.475055] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 2.475091] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.475134] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 2.475346] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.475351] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.475358] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.475497] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.475865] nvme nvme0: pci function 0005:01:00.0
[ 2.475896] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 2.485684] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 2.491400] tegra194-isp5 14800000.isp: initialized
[ 2.498143] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.500698] tegra194-vi5 15c10000.vi: initialized
[ 2.505061] tegra194-vi5 15c10000.vi: subdev arducam-csi2 9-000c bound
[ 2.505100] arducam-csi2 9-000c: subdev_registered: v4l2 subde registered.
[ 2.505106] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 2.505283] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (0)
[ 2.505288] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (1)
[ 2.505294] arducam-csi2 9-000c: arducam_csi2_get_fmt: width: (5120) height: (800) code: (0x2001)
[ 2.505719] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 2.506419] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.588670] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 2.588988] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.589321] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 2.589536] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 2.589839] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 2.589927] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 2.590176] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 2.590208] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.591418] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 2.591845] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 2.591917] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 2.592055] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.595959] nvme0n1: p1
[ 2.623274] tegra_rtc c2a0000.rtc: setting system clock to 2020-11-27 07:20:13 UTC (1606461613)
[ 2.623679] mmcblk mmc0:5048: Card claimed for testing.
[ 2.654187] usb 1-2: usb_suspend_both: status 0
[ 2.657139] bpmp: mounted debugfs mirror
[ 2.663305] vdd-1v8-sd: disabling
[ 2.663311] vdd-1v8-cvb: disabling
[ 2.663315] vdd-epb-1v0: disabling
[ 2.663318] avdd-cam-2v8: disabling
[ 2.663321] vdd-fan: disabling
[ 2.663324] vdd_sys_en: disabling
[ 2.663332] ALSA device list:
[ 2.663336] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 2.663340] #1: jetson-xaviernx-ape
[ 2.665883] Freeing unused kernel memory: 8576K
[ 2.703720] Root device found: mmcblk0p1
[ 2.704983] Found dev node: /dev/mmcblk0p1
[ 2.815350] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.816372] Rootfs mounted over mmcblk0p1
[ 2.839501] Switching from initrd to actual rootfs
[ 3.100428] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.105008] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.119028] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.119707] systemd[1]: Detected architecture arm64.
[ 3.128069] systemd[1]: Set hostname to <nx-xaviernxkit>.
[ 3.228372] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.228406] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.367277] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.370256] systemd[1]: Created slice System Slice.
[ 3.370523] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.370658] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.370685] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.371677] systemd[1]: Created slice User and Session Slice.
[ 3.372105] systemd[1]: Listening on Journal Socket.
[ 3.375978] systemd[1]: Starting Set the console keyboard layout…
[ 3.422437] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.517173] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 3.518345] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: errors=remount-ro,discard
[ 3.678173] systemd-journald[2344]: Received SIGTERM from PID 1 (systemd).
[ 3.701975] systemd: 38 output lines suppressed due to ratelimiting
[ 4.224929] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.225548] systemd[1]: Detected architecture arm64.
[ 4.226630] systemd[1]: Set hostname to <nx-xaviernxkit>.
[ 4.288959] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.289320] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.403690] systemd[1]: Started Journal Service.
[ 4.411338] systemd[1]: sys-kernel-config.mount: Mount process finished, but there is no mount.
[ 4.411573] systemd[1]: sys-kernel-config.mount: Failed with result ‘protocol’.
[ 4.414566] systemd[1]: Started Apply Kernel Variables.
[ 4.415046] systemd[1]: systemd-udevd.service: Failed with result ‘protocol’.
[ 4.605165] systemd-journald[3113]: Received request to flush runtime journal from PID 1
[ 5.538309] random: crng init done
[ 5.538426] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.825216] using random self ethernet address
[ 5.826278] using random host ethernet address
[ 5.894529] Wake76 for irq=199
[ 5.894535] Wake77 for irq=199
[ 5.894547] Wake78 for irq=199
[ 5.894550] Wake79 for irq=199
[ 5.894553] Wake80 for irq=199
[ 5.894556] Wake81 for irq=199
[ 5.894559] Wake82 for irq=199
[ 5.894786] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.894792] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.219165] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 6.255347] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 6.255356] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.255361] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.255365] usb 2-3: Manufacturer: Generic
[ 6.266084] hub 2-3:1.0: USB hub found
[ 6.268239] hub 2-3:1.0: 4 ports detected
[ 6.380597] Mass Storage Function, version: 2009/09/11
[ 6.380606] LUN: removable file: (no medium)
[ 6.386682] using random self ethernet address
[ 6.386809] using random host ethernet address
[ 6.404152] rndis0: HOST MAC da:7d:9d:2e:ce:44
[ 6.406651] rndis0: MAC da:7d:9d:2e:ce:45
[ 6.408597] usb0: HOST MAC da:7d:9d:2e:ce:46
[ 6.408638] usb0: MAC da:7d:9d:2e:ce:47
[ 6.408662] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.409521] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.409540] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.409579] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.409778] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.409804] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 6.410294] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 6.410334] tegra-xudc-new 3550000.xudc: entering ELPG
[ 6.410558] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.416013] l4tbr0: port 1(rndis0) entered blocking state
[ 6.416022] l4tbr0: port 1(rndis0) entered disabled state
[ 6.416829] device rndis0 entered promiscuous mode
[ 6.426782] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.433372] l4tbr0: port 2(usb0) entered blocking state
[ 6.433391] l4tbr0: port 2(usb0) entered disabled state
[ 6.433808] device usb0 entered promiscuous mode
[ 6.443326] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.641806] usbcore: registered new interface driver btusb
[ 6.644499] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 6.644508] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 6.644513] rtk_btcoex: create workqueue
[ 6.650060] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 6.650306] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 6.650312] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 6.650315] rtk_btusb: patch_add
[ 6.650319] rtk_btusb: auto suspend is disabled
[ 6.650324] rtk_btusb: pid = 0x3549
[ 6.650329] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 6.650339] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 6.661882] rtk_btusb: btusb_probe: done
[ 6.661899] rtk_btusb: btusb_open start
[ 6.661906] rtk_btusb: btusb_open hdev->promisc ==0
[ 6.661961] usbcore: registered new interface driver rtk_btusb
[ 6.662046] rtk_btusb: download_patch start
[ 6.662052] rtk_btusb: chip type value: 0x73
[ 6.662057] rtk_btusb: HCI reset.
[ 6.672595] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 6.672603] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 6.672607] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.672611] rtk_btusb: load_firmware start
[ 6.672616] rtk_btusb: lmp_version = 0x8822
[ 6.672620] rtk_btusb: config filename rtl8822cu_config
[ 6.673143] rtk_btusb: no bdaddr file /opt/bdaddr
[ 6.673150] rtk_btusb: 55 ab 23 87 00 00
[ 6.673162] rtk_btusb: Config file length 6, new length 6
[ 6.673166] rtk_btusb: fw name is rtl8822cu_fw
[ 6.673638] rtk_btusb: This is not 8723a, use new patch style!
[ 6.673786] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 6.674576] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 6.674582] rtk_btusb: load_firmware: New gEVersion 3
[ 6.674587] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 6.674591] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 6.674595] rtk_btusb: fw_version = 0x98a42f7
[ 6.674598] rtk_btusb: number_of_total_patch = 3
[ 6.674601] rtk_btusb: chipID 4
[ 6.674605] rtk_btusb: patch_length 0x55f0
[ 6.674608] rtk_btusb: start_offset 0x00005d00
[ 6.674612] rtk_btusb: Svn version: 21761
[ 6.674616] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 6.674619] rtk_btusb: buf_len = 0x55f6
[ 6.674632] rtk_btusb: fw: exists, config file: exists
[ 6.674635] rtk_btusb: load_firmware done
[ 6.674657] rtk_btusb: download_data start
[ 6.722006] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.765156] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.788604] rtk_btusb: download_data done
[ 6.788614] rtk_btusb: HCI reset.
[ 6.799601] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 6.799610] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 6.799615] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.799626] rtk_btusb: Rtk patch end 0
[ 6.799631] rtk_btusb: btusb_open set HCI_RUNNING
[ 6.799675] rtk_btcoex: Open BTCOEX
[ 6.799680] rtk_btusb: btusb_open end
[ 6.809641] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 6.809650] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 6.829596] rtk_btusb: btusb_notify: hci0 evt 3
[ 6.862228] usb 2-3: usb_suspend_both: status 0
[ 6.862448] usb usb2: usb_suspend_both: status 0
[ 6.921680] zram: Added device: zram0
[ 6.923608] zram: Added device: zram1
[ 6.926093] zram: Added device: zram2
[ 6.931103] zram: Added device: zram3
[ 6.933432] zram: Added device: zram4
[ 6.935702] zram: Added device: zram5
[ 6.979975] zram0: detected capacity change from 0 to 679084032
[ 7.005048] Adding 663164k swap on /dev/zram0. Priority:5 extents:1 across:663164k SS
[ 7.009619] zram1: detected capacity change from 0 to 679084032
[ 7.042736] Adding 663164k swap on /dev/zram1. Priority:5 extents:1 across:663164k SS
[ 7.046304] zram2: detected capacity change from 0 to 679084032
[ 7.063779] Adding 663164k swap on /dev/zram2. Priority:5 extents:1 across:663164k SS
[ 7.070480] zram3: detected capacity change from 0 to 679084032
[ 7.083063] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.096119] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.105274] Adding 663164k swap on /dev/zram3. Priority:5 extents:1 across:663164k SS
[ 7.111450] zram4: detected capacity change from 0 to 679084032
[ 7.128694] Adding 663164k swap on /dev/zram4. Priority:5 extents:1 across:663164k SS
[ 7.133885] zram5: detected capacity change from 0 to 679084032
[ 7.155494] Adding 663164k swap on /dev/zram5. Priority:5 extents:1 across:663164k SS
[ 7.869506] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.003405] rtk_btusb: btusb_flush add delay
[ 8.014382] rtk_btusb: btusb_close
[ 8.028695] rtk_btcoex: Close BTCOEX
[ 8.028707] rtk_btcoex: -x
[ 8.074875] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.074894] Bluetooth: BNEP socket layer initialized
[ 8.178174] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.181403] tegradc 15200000.nvdisplay: blank - powerdown
[ 8.181419] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.295196] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.564859] fuse init (API version 7.26)
[ 12.984254] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.200284] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 51.475506] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 640, height: 480
[ 51.477851] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 5120, height: 800
[ 51.477866] arducam-csi2 9-000c: arducam_csi2_set_fmt: format match.
[ 51.477871] arducam-csi2 9-000c: arducam_csi2_set_fmt: set format to device: 0 0.
[ 51.479486] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 5120, height: 800
[ 51.479493] arducam-csi2 9-000c: arducam_csi2_set_fmt: format match.
[ 51.479497] arducam-csi2 9-000c: arducam_csi2_set_fmt: set format to device: 0 0.
[ 51.481006] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 5120, height: 800
[ 51.481012] arducam-csi2 9-000c: arducam_csi2_set_fmt: format match.
[ 51.481016] arducam-csi2 9-000c: arducam_csi2_set_fmt: set format to device: 0 0.
[ 51.569075] arducam-csi2 9-000c: arducam_csi2_s_stream: stream on
[ 51.582196] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 62.874539] arducam-csi2 9-000c: arducam_csi2_s_stream: stream off
[ 63.026567] FAN rising trip_level:1 cur_temp:46100 trip_temps[2]:60000
[ 153.752358] FAN cooling trip_level:0 cur_temp:37950 trip_temps[1]:46000
Here there is the output of mplayer for Tegra Release R32 4.3:
nx@nx-xaviernxkit:~$ mplayer tv:// -tv driver=v4l2:device=/dev/video0
MPlayer 1.3.0 (Debian), built with gcc-7 (C) 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv://.
TV file format detected.
Selected driver: v4l2
name: Video 4 Linux 2 input
author: Martin Olschewski <[email protected]>
comment: first try, more to come
v4l2: ioctl get standard failed: Inappropriate ioctl for device
Selected device: vi-output, arducam-csi2 9-000c
Capabilities: video capture streaming
supported norms:
inputs: 0 = Camera 0;
Current input: 0
Current format: GREY
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
v4l2: ioctl enum norm failed: Inappropriate ioctl for device
Error: Cannot set norm!
Selected input hasn’t got a tuner!
v4l2: ioctl set mute failed: Invalid argument
v4l2: ioctl query control failed: Invalid argument
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [raw] RAW Uncompressed Video
Could not find matching colorspace - retrying with -vf scale…
Opening video filter: [scale]
Movie-Aspect is undefined - no prescaling applied.
[swscaler @ 0x5582d6ae30] bicubic scaler, from gray to yuv420p using C
VO: [xv] 5120x800 => 5120x800 Planar YV12
Selected video codec: [rawy800] vfm: raw (RAW Y8/Y800)
Audio: no sound
Starting playback…
[ASPECT] Warning: No suitable new res found!
V: 0.0 215/215 ??% ??% ??,?% 0 0
v4l2: 218 frames successfully processed, 58 frames dropped.
Exiting… (Quit)
Regards.
