Quadrascopic Camera B0267 Not Detected By RPI4
    UCTronics
    B0267
    Raspberry Pi 4 Bullseye
    Quick Start Guide for Arducam CamArray HAT Kit - Arducam Wiki
  5. Problems you were having?
    I purchased two B0267s and both stopped working. I used the second one for a few days before it stopped being detected by my raspberry pi.
[ 8.066842] arducam-pivariety 10-000c: firmware version: 0x10003
[ 8.424279] imx219 10-0010: failed to read chip id 219
[ 8.571101] imx219: probe of 10-0010 failed with error -5
[ 9.073584] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
System Log
 Linux pi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
 PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
 NAME="Debian GNU/Linux"
 VERSION_ID="11"
 VERSION="11 (bullseye)"
 VERSION_CODENAME=bullseye
 ID=debian
 MemTotal:        7999832 kB
 MemFree:         6772904 kB
 MemAvailable:    7210056 kB
 Buffers:           22648 kB
 Cached:           760000 kB
 SwapCached:            0 kB
 Active:            84012 kB
 Inactive:         842508 kB
 Active(anon):       1128 kB
 Inactive(anon):   402780 kB
 Active(file):      82884 kB
 Inactive(file):   439728 kB
 Unevictable:      148896 kB
 Mlocked:              16 kB
 SwapTotal:        102396 kB
 SwapFree:         102396 kB
 Dirty:               180 kB
 Writeback:             0 kB
 AnonPages:        292880 kB
 Mapped:           384648 kB
 Shmem:            260036 kB
 KReclaimable:      29648 kB
 Slab:              58580 kB
 SReclaimable:      29648 kB
 SUnreclaim:        28932 kB
 KernelStack:        4320 kB
 PageTables:         7268 kB
 NFS_Unstable:          0 kB
 Bounce:                0 kB
 WritebackTmp:          0 kB
 CommitLimit:     4102312 kB
 Committed_AS:    1870656 kB
 VmallocTotal:   259653632 kB
 VmallocUsed:       11916 kB
 VmallocChunk:          0 kB
 Percpu:              688 kB
 CmaTotal:         327680 kB
 CmaFree:          267964 kB
 # http://rpf.io/configtxt
 #hdmi_safe=1
 #overscan_left=16
 #overscan_right=16
 #overscan_top=16
 #overscan_bottom=16
 # overscan.
 #framebuffer_width=1280
 #framebuffer_height=720
 #hdmi_force_hotplug=1
 #hdmi_group=1
 #hdmi_mode=1
 #hdmi_drive=2
 # uncomment to increase signal to HDMI, if you have nterference, blanking, or
 # no display
 #config_hdmi_boost=4
 # uncomment for composite PAL
 #sdtv_mode=2
 #arm_freq=800
 # Uncomment some or all of these to enable the optional ardware interfaces
 #dtparam=i2c_arm=on
 #dtparam=i2s=on
 #dtparam=spi=on
 dtoverlay=imx219
 # Additional overlays and parameters are documented boot/overlays/README
 dtparam=audio=on
 camera_auto_detect=0
 display_auto_detect=1
 # Enable DRM VC4 V3D driver
 dtoverlay=vc4-kms-v3d
 max_framebuffers=2
 # Run in 64-bit mode
 arm_64bit=1
 disable_overscan=1
 [cm4]
 otg_mode=1
 [pi4]
 arm_boost=1
 dtoverlay=arducam
  • reconnecting all the connections and rebooting several times
  • trying the board on a rpi3
  • swapping out the cameras
  • updating my rpi and reinstalling the drivers
  • measuring the voltage on the four cameras (cameras connected to MIPI RX3 and 2 are getting 3V while RX0 and 1 are getting 2)
  1. What help do you need?
    Are there any self tests I can do to figure out whether this is a hardware or software problem. Also getting the schematics for the Camarray Hat would be great so I can figure out where the power delivery is going wrong.
update:
I added
dtoverlay=imx519
dtoverlay=imx519,cam0
to /boot/config.txt. Now /dev/video0 shows up but I get errors when trying to take pictures
[0:06:25.001122745] [2887]  INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4185-8c2b3b43
[0:06:25.021348146] [2890]  WARN CameraSensorProperties camera_sensor_properties.cpp:205 No static properties available for 'arducam-pivariety'
[0:06:25.021455117] [2890]  WARN CameraSensorProperties camera_sensor_properties.cpp:207 Please consider updating the camera sensor properties database
[0:06:25.046990303] [2890] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety_mono.json' not found for IPA module 'raspberrypi'
[0:06:25.218505537] [2890]  INFO RPI raspberrypi.cpp:1425 Registered camera /base/soc/i2c0mux/i2c@1/arducam_pivariety@c to Unicam device /dev/media4 and ISP device /dev/media0
[0:06:25.219258961] [2887]  INFO Camera camera.cpp:1028 configuring streams: (0) 2560x400-YUV420
[0:06:25.294079930] [2890]  INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/arducam_pivariety@c - Selected sensor format: 2560x400-Y10_1X10 - Selected unicam format: 2560x400-Y10P
[0:06:27.150910640] [2890]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[12:cap]: Dequeue timer of 1000000.00us has expired!
[0:06:27.151014629] [2890] ERROR RPI raspberrypi.cpp:1903 Unicam has timed out!
[0:06:27.151036723] [2890] ERROR RPI raspberrypi.cpp:1904 Please check that your camera sensor connector is attached securely.
[0:06:27.151058188] [2890] ERROR RPI raspberrypi.cpp:1905 Alternatively, try another cable and/or sensor.
[0:06:28.479359148] [2890]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[12:cap]: Dequeue timer of 1000000.00us has expired!
Please contact [email protected] for further help and post this thread.
