My goal is to record video with Quad Camera Kit IMX519. However, it produces broken frames.
config
sensorID=0
compositionMode=4-Channel
sku=B0388
captureWidth=3840
captureHeight=2160
# (0): none - Identity (no rotation)
# (2): rotate-180 - Rotate 180 degress
# (6): vertical-flip - Flip vertically
flipMethod=2
frameRate=4
displayWidth=3840
displayHeight=2160
# if 1 CSI interface is connected
# NOTE: use CAM1 instead of CAM0
# CAM1; sensorID=0; i2cBus=9
# if 2 CSI interface are connected
# CAM0; sensorID=1; i2cBus=10
i2cBus=9
roiCamID=0
GStreamer Pipeline
pipeline << "nvarguscamerasrc sensor-id=" << sensorID << " ! "
<< "video/x-raw(memory:NVMM),width=(int)" << captureWidth << ",height=(int)" << captureHeight << ",format=(string)NV12,framerate=(fraction)" << frameRate << "/1 ! "
// Enable hardware acceleration. This will use the Jetson's hardware encoder to accelerate video processing.
<< "nvvidconv flip-method=" << flipMethod << " ! "
<< "video/x-raw,width=(int)" << displayWidth << ",height=(int)" << displayHeight << ",format=(string)BGRx ! "
<< "videoconvert ! "
<< "video/x-raw,format=(string)BGR ! "
<< "appsink";
Is this because of frameRate=4 ? However, what confuses me is that I can use frameRate=3 but not frameRate=2 when using the default mode.
