Arducam -
B0388 -
Raspberry Pi -
Arducam quickstart page -
Setting focus -
I’m trying to setup my quad camera so that each camera has a different focus and them I’m takeing a syhcronous image. I’ve tried setting each camera to single mode using an i2c command, setting the focus of the camera and moving ot the next camera. Then when I have finished I’m setting the mode to quad cam and taking an image but it doesn’t seem to store the focus between switching to different modes. I’ve tried both starting and stopping the picamera instance and not doing so. This is my code:
from smbus2 import SMBus
import timequad = 4
camera = (0x02, 0x12, 0x22, 0x32, 0x00)
focus = (0.0, 2.5, 5.0, 10.0)
bus = SMBus(11)def select_camera(number):
bus.write_byte_data(0x24, 0x24, camera[number])for cam_num in range(4):
select_camera(cam_num)
time.sleep(1)
picam2 = Picamera2(0)
picam2.start()
picam2.set_controls({“AfMode”: 0, “LensPosition”: focus[cam_num]})picam2.stop() picam2.close()select_camera(quad)
picam2.start()
picam2.capture_file(“image.png”)
picam2.stop()
picam2.close()
Is there a low level way of achieving this with i2c calls; preferably without needing to stop and start picamera. I’m doing this because I need to set a very fine focus with the system.
Thanks.
Regards,
Neil
