Arducam 12MP 477P Pan Tilt Zoom(PTZ)
Raspberry pi 4 -
https://docs.arducam.com/Raspberry-Pi-Camera/Pan-Tilt-Zoom-Camera/quick-start/
PTZ focus motor is really inaccurate, for example using the tool provided in the instructions: -
When setting the focus distance, if I target 15,000 and then increase it step-by-step, there is a point (usually around 16,000) where the numerical value increases, but the actual focus position in the preview remains unchanged.
Using the default step size, if I move the focus one step forward and then one step backward, the preview image may not return to its original position.
Verifying correct power and cable connection and that movement has no friction. -
I’ve researched this issue online and found that stepper motor driver problems can be a potential cause. Could this behavior be normal for the product, or is it likely defective?
