PTZ board focus/zoom: stepper type, driver current, and motor pinout for Pi 4/IMX477?
Hi all, I’m in the design/trial stage of putting together an autofocus setup with a zoom microscope lens and I came across the PTZ control board. I only plan to use the board for the autofocus and zoom control — the pan/tilt section isn’t needed for my build, so I’d basically be driving just the focus and zoom motors.
Before I wire anything up, a few things I’m trying to confirm:
  1. Is it correct that the focus and zoom are each controlled by a separate 4-wire bipolar stepper? That’s my assumption but I want to make sure before I start sourcing drivers/harness.
  2. What is the rated current output of the driver on the PTZ board — specifically the rated current per channel? I need this to size things properly.
  3. Can you share the pinout of the motor connector?
For context, this will run off a Raspberry Pi 4 with an IMX477 sensor. Any info would help me move forward.
Hey, happy to help with the design-side questions.
First one is an easy confirm: yes, your assumption is correct — the focus and zoom on this board are controlled by two separate 4-wire bipolar steppers. So you’re looking at two independent bipolar drivers, one per axis, and you can ignore the pan/tilt side entirely for your use case.
For the Zoom and Focusing system, here are the operational and electrical specs:
  • Operation method: stepping motor drive
  • Coil resistance: 50Ω ±10% / phase (T = 25 ±5℃)
  • Operation voltage: 5V
  • Rate range: 800 pps – 1200 pps
  • Excitation method: 2-2 phase excitation mode
Regarding the driver’s rated output current per channel — I want to make sure I give you the exact figure and not a general number, so let me double-check the board revision you’re working with. Can you confirm which board version/silkscreen you have? In the meantime, the motor-side specs above should get you started on the electrical side.
For the motor connector pinout, I’ll pull the connector drawing and attach it to this thread so you have the definitions.
Thanks, that confirms a lot. Good to know it’s two 4-wire bipolar steppers and that the pan/tilt side is fully separate.
One thing though — the coil resistance is listed as 50Ω ±10% per phase at 5V. With 800–1200 pps and 2-2 phase excitation, that’s a fairly low-resistance winding for a 5V rail. I’m trying to figure out how much current the driver is expected to push per phase so I can match it, or at least not cook the motors while I’m prototyping on the Pi 4.
Can you confirm the rated current per channel? That’s the number I really need. I don’t have anything wired up yet — no code running, nothing to log — this is all still pre-build sizing so far.
That’s a fair concern, and you’re right to size the current before you wire it up.
On the current side: the motors are driven in 2-2 phase excitation mode, so two phases are energized at a time rather than all four, which is part of why the windings can be this low-resistance on a 5V rail. I haven’t been able to pin down the exact per-channel rated current for your specific board revision yet, so I don’t want to hand you a number that turns out to be wrong — I’ll follow up once I confirm it against the correct revision.
What I can give you definitively right now is the motor-side spec, which is what matters most for matching the drive:
The pin definitions for the motor connector are in the attached image on this thread — that covers how the four wires per motor map to the connector, for both the zoom and focus motors.
If it helps, post a quick description or photo of your board’s connector and silkscreen when you get a chance, and I’ll match it against the drawing so you’re sure you’ve got the right orientation before powering anything.
Ok, that makes sense on the 2-2 phase excitation — two phases energized at a time, so the per-phase current draw works out differently than a full 4-phase drive.
I’ve got the pin definitions from the attached image, thanks. Just to be clear on my end: I’ll be treating zoom and focus as two independent 4-wire bipolars, driving each in 2-2 phase mode, at 5V, within that 800–1200 pps range. I’ll start at the low end of the rate range and ramp up so I don’t stall the motors during bring-up.
Still keen on the rated current per channel whenever you can confirm it. If it’s not readily available for my revision, just let me know and I’ll work from the coil resistance spec as a starting point.
Sounds like you’ve got the right mental model. Summarizing where we’ve landed so far so the thread is a clean reference for anyone else doing this:
Confirmed / provided:
  • The focus and zoom on the PTZ board are controlled by two 4-wire bipolar steppers. The pan/tilt section is entirely separate and not required for a focus/zoom-only build.
  • Zoom and Focusing system specs:
  • Motor connector pin definitions: provided in the attached image on this thread. There’s no direct URL for it — refer to the attachment itself for the per-wire mapping of both the zoom and focus motors.
Still open:
  • The rated output current per channel of the driver on the board has not been confirmed for the specific revision yet. I’ll follow up here once I’ve verified it. Until then, your approach of starting at the low end of the 800–1200 pps range and working from the 50Ω/phase figure is a reasonable way to bring it up safely on the Pi 4 without over-driving the windings.
If you later hit stalls, missed steps, or heating when you get it wired, post your settings (step rate, excitation mode, supply) and we can dig into it.
