Product Q&A: Your Questions Answered
Hello everyone,
Recently, we have compiled a list of questions from customer feedback and have provided answers below. This will help other customers who might be facing similar issues find solutions quickly. If you have deeper insights into these questions, please feel free to share your thoughts in this thread. However, if your question is not listed here, please start a new thread.
This thread is active and regularly updated.
1. Would the vlc capture device not get a picture from video0 or video1?
Background:
The customer used an IMX219 MIPI camera on Raspberry Pi 5.
A:
We use libcamera instead of VLC to stream the MIPI camera on Raspberry Pi. When libcamera starts, it enumerates all available camera devices in the system. This involves scanning the /dev directory for potential camera device files like /dev/video0 .
2. What’s the chance there are some problems with the a single connector doing displays/camera’s both. (Zero2 & RPI 5)
A:
On the Pi 5, the camera interface and the display interface do indeed share the same connector, but configuration is required in the config file. However, the Pi 0 does not support this feature.
3. Are there any demo Python codes available for streaming cameras on the Jetson platform?
Please do not install the official opencv, nvidia has released a customized version of opencv
sudo pip uninstall opencv-python
sudo pip3 uninstall opencv-python
sudo apt install nvidia-opencv
sudo apt install nvidia-opencv-dev
You can refer to the following example:
Note: The code examples are not suitable for all cameras. The resolution, frame rate, etc. need to match the actual situation.
4. Cannot Install Camera Driver on Jetson Orin Nano/NX and Jetson AGX Orin
First,
Verify Carrier Board Compatibility: Please ensure that you are using an official NVIDIA carrier board. Our drivers are not compatible with third-party carrier boards. If you are using a third-party board, this may be the cause of the issue.
Update to the Latest L4T Version: Flash your system to the latest L4T version 36.3.0. After updating, try installing the driver again. The latest updates may have resolved compatibility issues.
Then,
If you still cannot install it, please update the kernel to the latest one.
sudo apt-get update
sudo apt-get upgrade
sudo reboot
After restarting the system, re-execute the camera driver installation command.
5. Cannot get compile.sh working on the Jetson device.
Please follow the steps below.
# Clone Tof Repository
cd ~
git clone -b v1.0.3 https://github.com/ArduCAM/Arducam_tof_camera.git
cd Arducam_tof_camera
# Install Dependencies
./jetson/Install_dependecies_jetson.sh
wget https://github.com/ArduCAM/arducam_ppa/raw/master/pool/main/a/arducam-tof-sdk-dev/arducam-tof-sdk-dev_0.1.3_$(dpkg --print-architecture).deb -O arducam-tof-sdk-dev_0.1.3.deb
sudo dpkg -i arducam-tof-sdk-dev_0.1.3.deb
# Compile
./compile.sh
6. Camera Not Detected in Web UI After System Update
Issue: Some users have reported that after performing a system update, the web UI fails to detect the camera. This issue typically occurs after running the following update commands:
sudo apt update
sudo apt upgrade
These system-wide updates, while generally beneficial, can sometimes lead to unexpected compatibility issues with existing hardware or software configurations. In this case, the camera detection functionality in the web UI appears to be affected.
Solution: Reflash the System Image
To resolve this issue, we recommend the following steps:
  1. Reflash your device with the latest official image. You can download it from the following link: B0513 ArduCam 64MP Image (2024-05-22)
  2. After reflashing, it’s crucial to temporarily avoid system updates. This will help maintain the current configuration that is known to work correctly with the camera.
Important Notes:
  • Reflashing will erase all data on the device. Make sure to back up any important files before proceeding.
  • The provided image is specifically configured to work with the camera and web UI.
  • We are actively working on a more permanent solution that will allow for system updates without affecting camera functionality.
Troubleshooting Guide: Image Capture Timeout with Arducam 64MP Quad Kit on Raspberry Pi 4 and 5
Problem Description
When using the Raspberry Pi (4 or 5) with the Arducam 64MP Quad Kit to capture images at maximum resolution, users may encounter a timeout error. This issue occurs when executing the following command:
libcamera-still -t 10000 -o test1.jpg --width 9152 --height 6944
The error message typically indicates a timeout during the image capture process.
Solution
The solution differs depending on whether you’re using a Raspberry Pi 4 or Pi 5.
For Raspberry Pi 5
  1. Download the rpi_apps.yaml file from the provided link. rpi_apps.yaml - Google Drive
  2. Place the rpi_apps.yaml file in the following directory:
/usr/share/libcamera/pipeline/rpi/pisp/
  1. Set the following environment variable:
export LIBCAMERA_RPI_CONFIG_FILE=/usr/share/libcamera/pipeline/rpi/pisp/rpi_apps.yaml
  1. To make this change permanent, add the above line to your ~/.bashrc file:
echo 'export LIBCAMERA_RPI_CONFIG_FILE=/usr/share/libcamera/pipeline/rpi/pisp/rpi_apps.yaml' >> ~/.bashrc
  1. Apply the changes using the source command:
source ~/.bashrc
For Raspberry Pi 4
  1. Edit the following file:
/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml
  1. Add the following line to the file (ensure to include the comma):
"camera_timeout_value_ms": 50000,
  1. Save the file.
  2. Set the following environment variable:
export LIBCAMERA_RPI_CONFIG_FILE=/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml
echo 'export LIBCAMERA_RPI_CONFIG_FILE=/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml' >> ~/.bashrc
source ~/.bashrc
Applying Changes
After making these changes, you need to apply them:
  1. If you’ve edited ~/.bashrc manually, run:
source ~/.bashrc
  1. Alternatively, you can restart your Raspberry Pi to ensure all changes take effect:
sudo reboot
Verification
After applying the changes, try running the image capture command again:
The timeout issue should now be resolved, allowing you to capture images at maximum resolution without errors.
Cannot install libcamera in Arducam version
You may get the error below when you run ./install_pivariety_pkgs.sh so you cannot manage to install arducam libcamera.
Solution
We have implemented a temporary solution to address this issue.
Before proceeding, ensure you have run the command:
./install_pivariety_pkgs.sh -p libcamera
This should have downloaded three essential packages into your current directory:
  1. libcamera
  2. libcamera-ipa
  3. libcamera-dev
To resolve the conflict, please follow these steps to manually install the packages:
  1. First, verify the presence of the libcamera deb packages:
ls
  1. Then, install each package using the following commands:
sudo apt install ./libcamera-ipa_0.3.1+rpt20240909-1_arm64.deb
sudo apt install ./libcamera0.3_0.3.1+rpt20240909-1_arm64.deb
sudo apt install ./libcamera-dev_0.3.1+rpt20240909-1_arm64.deb
Moreover, you can ignore this not when running the commands above.
I works, but only if you reinstall raspberry pi and don’t update it when it works
May I know which problem you sorted out?
This one? Product Q&A: Your Questions Answered - #20 by Dion
