I have been trying to set up the camarray hat to use with a Raspberry Pi 4B. I have followed all of the start up guides and have implemented the change in the boot/config.txt file so that it now looks like this:
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
start_x=1
camera_auto_detect=1
dtoverlay=imx219,vcm
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-fkms-v3d
arm_boost=1
gpu_mem=256
dtoverlay=gpio-fan,gpiopin=14,temp=80000
But I have also tried this file with start_x=0 and with it commented out, as well as with camera_auto_detect=0 and commented out and with dtoverlay=imx219 commented out, and in every combination.
Running vcgencmd get_camera gives
supported=1 detected=0, libcamera interfaces=1
but running libcamera-hello --tuning-file=/usr/share/libcamera/ipa/rpi/vc4/imx219_af.json
Preview window unavailable
[0:08:06.572516364] [1951] INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[0:08:06.624435654] [1954] WARN RPI vc4.cpp:390 Mismatch between Unicam and CamHelper for embedded data usage!
[0:08:06.625343389] [1954] INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/imx219@10 to Unicam device /dev/media0 and ISP device /dev/media1
[0:08:06.625445386] [1954] INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:08:06.626409861] [1951] INFO Camera camera.cpp:1033 configuring streams: (0) 1640x1232-YUV420
[0:08:06.627019881] [1954] INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/imx219@10 - Selected sensor format: 1640x1232-SBGGR10_1X10 - Selected unicam format: 1640x1232-pBAA
[0:08:06.628631950] [1954] ERROR V4L2 v4l2_device.cpp:353 'ad5398 focus': Unable to set controls: Remote I/O error
[0:08:07.702528396] [1954] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[14:cap]: Dequeue timer of 1000000.00us has expired!
[0:08:07.702691225] [1954] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:08:07.702735779] [1954] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:08:07.702775760] [1954] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
I have also tried this directly on the raspberry pi, in which case it gives a completely black screen with the same error messages. I have obviously checked the cables and changed them over, as well as trying with different camera modules, but the result is always the same. I have two of these camarray hats, and they both behave in the same way.
Using libcamera-hello --list-cameras gives
Available cameras
0 : imx219 [3280x2464 10-bit RGGB] (/base/soc/i2c0mux/i2c@1/imx219@10)
Modes: 'SRGGB10_CSI2P' : 640x480 [103.33 fps - (1000, 752)/1280x960 crop]
1640x1232 [41.85 fps - (0, 0)/3280x2464 crop]
1920x1080 [47.57 fps - (680, 692)/1920x1080 crop]
3280x2464 [21.19 fps - (0, 0)/3280x2464 crop]
'SRGGB8' : 640x480 [103.33 fps - (1000, 752)/1280x960 crop]
I have checked the connections with i2cdetect -y 10 (which I was have seen is the one to check in other forums)
i2cdetect -y 10
00: -- -- -- -- UU -- -- --
10: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- 24 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I have been trying for over 2 weeks to get these cameras and camarray hat to work, so any help would be much appreciated.
