When arducam imx519 fixed focus is connected to raspberry pi
vcgencmd get_camera gives output: supported=1 detected=0, libcamera interfaces=1
and
libcamera-hello gives output: [1:48:03.940460157] [4504] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+246-9fb4698e-dirty (2024-02-27T05:56:04+00:00)
[1:48:03.990895674] [4507] WARN RPiSdn sdn.cpp:39 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[1:48:03.993208519] [4507] INFO RPI vc4.cpp:455 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media1
[1:48:03.993277259] [4507] INFO RPI pipeline_base.cpp:1169 Using configuration file ‘/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
Preview window unavailable
Mode selection for 2328:1748:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 5319.24
SRGGB10_CSI2P,1920x1080/0 - Score: 3319.24
SRGGB10_CSI2P,2328x1748/0 - Score: 1000
SRGGB10_CSI2P,3840x2160/0 - Score: 1648.24
SRGGB10_CSI2P,4656x3496/0 - Score: 2019
Stream configuration adjusted
[1:48:03.998911097] [4504] INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-SRGGB10_CSI2P
[1:48:03.999309257] [4507] INFO RPI vc4.cpp:619 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
#0 (0.00 fps) exp 32844.00 ag 6.02 dg 1.33
#1 (30.00 fps) exp 32844.00 ag 6.02 dg 1.33
#2 (30.00 fps) exp 32844.00 ag 6.02 dg 1.33
#3 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#4 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#5 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#6 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#7 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#8 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#9 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#10 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#11 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#12 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#13 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#14 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#15 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#16 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#17 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#18 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#19 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#20 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#21 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#22 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#23 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#24 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#25 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#26 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#27 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#28 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#29 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#30 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#31 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#32 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#33 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#34 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#35 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#36 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#37 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#38 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#39 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#40 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#41 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#42 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#43 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#44 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#45 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#46 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#47 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#48 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#49 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#50 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#51 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#52 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#53 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#54 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#55 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#56 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#57 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#58 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#59 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#60 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#61 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#62 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#63 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#64 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#65 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#66 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#67 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#68 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#69 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#70 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#71 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#72 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#73 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#74 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#75 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#76 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#77 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#78 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#79 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#80 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#81 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#82 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#83 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#84 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#85 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#86 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#87 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#88 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#89 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#90 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#91 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#92 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#93 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#94 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#95 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#96 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#97 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#98 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#99 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#100 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#101 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#102 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#103 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#104 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#105 (29.99 fps) exp 32844.00 ag 8.00 dg 1.00
#106 (30.01 fps) exp 32844.00 ag 8.00 dg 1.00
#107 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#108 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#109 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#110 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#111 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#112 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#113 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#114 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#115 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#116 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#117 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#118 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#119 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#120 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#121 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#122 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#123 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#124 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#125 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#126 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#127 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#128 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#129 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#130 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#131 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#132 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#133 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#134 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#135 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#136 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#137 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#138 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#139 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#140 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
#141 (30.00 fps) exp 32844.00 ag 8.00 dg 1.00
When i try to used it with a python code using OpenCV i get following error:
[ WARN:[email protected]] global ./modules/videoio/src/cap_v4l.cpp (1013) tryIoctl VIDEOIO(V4L2:/dev/video0): select() timeout.
I have made following changes in config.txt:
camera_auto_detect = 0
start_x = 1
dtoverlay = imx519
vmc = off
