UCTRONICS
B0167B12
Raspberry Pi 3B+/4B
Online documentation
Still Setting up
I have recently bought an Arducam IMX477 12MP PTZ Camera, which includes the two servos which I’m trying to get working for the first time. I can see where all the cables go on the Raspberry Pi apart from the two labelled ‘Servo VCC’/‘GND’ on the diagram at:
https://www.arducam.com/docs/cameras-for-raspberry-pi/ptz-camera/hardware/
From looking at the video of the camera at:
It looks like it’s being powered from a USB cable, but the video isn’t 100% clear.
Please can you tell me:
What voltage the servos need and what is their maximum current draw?
If I can simply connect these Servo VCC cables to pins on a Raspberry Pi 3B+/4B board?
If I can draw the power from a USB port on a Raspberry Pi?
If so is there are is an off the shelf connector to convert from a USB A male connector to pins suitable for the Servo VCC connectors?
Read the documentation, searched the forums and Googled.
Answer my four questions, about powering the servos.
