1st is more of a request, I would need higher FPS mode, while dynamic mode(FPS is calculated by ROI, smaller ROI, larger FPS) would be perfect, I am fine with adding just one 120FPS@720P, unbinned mode. I know fps it is limited due to 2 CSI2 lanes, but 120fps at 720p should be more than fine.
2nd Long exposure mode is simply not working that is a bug, or I have some old firmware?
oook so I tried to sudo apt uprade, that failed completely, so I reinstalled again good version of Bullseye, and now still nothing works. Mind you the IMX290 driver without pivariety board works as expected. It seems that this firmware_update actually did something, but it just broke the Pivariety board.
astroberry@raspberrypi:~ $ dmesg | grep arducam
[ 6.422508] arducam: loading out-of-tree module taints kernel.
[ 6.758535] arducam-pivariety 10-000c: probe failed
astroberry@raspberrypi:~ $ ^C
astroberry@raspberrypi:~ $ ls /dev/video* -l
crw-rw----+ 1 root video 81, 2 Aug 31 15:31 /dev/video10
crw-rw----+ 1 root video 81, 3 Aug 31 15:31 /dev/video11
crw-rw----+ 1 root video 81, 10 Aug 31 15:31 /dev/video12
crw-rw----+ 1 root video 81, 0 Aug 31 15:31 /dev/video13
crw-rw----+ 1 root video 81, 1 Aug 31 15:31 /dev/video14
crw-rw----+ 1 root video 81, 4 Aug 31 15:31 /dev/video15
crw-rw----+ 1 root video 81, 5 Aug 31 15:31 /dev/video16
crw-rw----+ 1 root video 81, 11 Aug 31 15:31 /dev/video18
crw-rw----+ 1 root video 81, 6 Aug 31 15:31 /dev/video20
crw-rw----+ 1 root video 81, 7 Aug 31 15:31 /dev/video21
crw-rw----+ 1 root video 81, 8 Aug 31 15:31 /dev/video22
crw-rw----+ 1 root video 81, 9 Aug 31 15:31 /dev/video23
crw-rw----+ 1 root video 81, 12 Aug 31 15:31 /dev/video31
astroberry@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
astroberry@raspberrypi:~ $ cat /etc/os-release
cat /proc/meminfo
cat /boot/config.txt
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
MemTotal: 931452 kB
MemFree: 181444 kB
MemAvailable: 632132 kB
Buffers: 26312 kB
Cached: 477264 kB
SwapCached: 0 kB
Active: 87456 kB
Inactive: 547540 kB
Active(anon): 996 kB
Inactive(anon): 152552 kB
Active(file): 86460 kB
Inactive(file): 394988 kB
Unevictable: 17332 kB
Mlocked: 16 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 148804 kB
Mapped: 136824 kB
Shmem: 22128 kB
KReclaimable: 28588 kB
Slab: 54868 kB
SReclaimable: 28588 kB
SUnreclaim: 26280 kB
KernelStack: 3772 kB
PageTables: 5188 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 568120 kB
Committed_AS: 1010072 kB
VmallocTotal: 259653632 kB
VmallocUsed: 10624 kB
VmallocChunk: 0 kB
Percpu: 688 kB
CmaTotal: 262144 kB
CmaFree: 113180 kB
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=arducam
Oh so that is a trick, I will burn 32bit version no problem. I had 64 bit laying around as I have 8GB and 1 GB version so. I will give my feedback after I try 32 bit.
Hi Edeward, I can confirm that Update has gone successfully and that I am able to take long exposure. If you could just add the note on update page that you need to use 32 bit version for future users if needed.
I would like to upgrade the firmware on my Pivariety B0333 to support the longer shutter times. I have tried to use the firmware_update tool from this posting:
I get a segmentation fault when trying to run ./firmware_update. This is on my Raspberry Pi Zero W running the 2023-05-03 release of raspios Bullseye. I get the segmentation fault even when running “./firmware_update -h”. Any ideas why this is not working for me?
