UCTRONICS # our Shipment #1000044768 for Order #1000032393 -
Quick-Start-Guide-for-Multi-Adapter-Board #for-quad-camera-adapter-boardb012001
4x Arducam Cameras
Raspberry-Pi-Camera Motorized-Focus-Camera Quick-Start-Guide OV5647-Motorized-Focus-Camera
Pi 5 -
One Cam detected, No image -
See below -
Check Cableig , Check Config, Enable I2C, Search forums
Clean Install Raspberry Pi 5 Os
apt-get update && apt-get upgrade -
I must be missing a driver or config or fault hardware?.
Usage ./diag.sh >> diags.txt 2>&1
------ dpkg -l | grep libcamera -----
ii libcamera-ipa:arm64 0.2.0+rpt20240418-1 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.2.0+rpt20240418-1 arm64 complex camera support library (tools)
ii libcamera0.2:arm64 0.2.0+rpt20240418-1 arm64 complex camera support library
ii pipewire-libcamera:arm64 0.3.65-3+rpt7+deb12u1 arm64 PipeWire libcamera plugin
ii python3-libcamera:arm64 0.2.0+rpt20240418-1 arm64 complex camera support library (Python bindings)
------ dmesg | grep ov56 ------
[ 0.569264] platform 1f00110000.csi: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/i2c@88000/ov5647@36
[ 3.129175] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@120000/rp1/i2c@88000/ov5647@36
[ 3.164448] rp1-cfe 1f00110000.csi: Using sensor ov5647 6-0036 for capture
------ uname -a ------
Linux pi-ai 6.6.28+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64 GNU/Linux
------ cat /etc/os-release ------
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
------ cat /proc/meminfo ------
MemTotal: 8244496 kB
MemFree: 6008048 kB
MemAvailable: 6958080 kB
Buffers: 38304 kB
Cached: 1202832 kB
SwapCached: 0 kB
Active: 1445056 kB
Inactive: 448144 kB
Active(anon): 884000 kB
Inactive(anon): 0 kB
Active(file): 561056 kB
Inactive(file): 448144 kB
Unevictable: 173312 kB
Mlocked: 0 kB
SwapTotal: 102384 kB
SwapFree: 102384 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 32 kB
Writeback: 0 kB
AnonPages: 825424 kB
Mapped: 401152 kB
Shmem: 231904 kB
KReclaimable: 29840 kB
Slab: 71056 kB
SReclaimable: 29840 kB
SUnreclaim: 41216 kB
KernelStack: 6992 kB
PageTables: 17168 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 4224624 kB
Committed_AS: 3649936 kB
VmallocTotal: 68180246528 kB
VmallocUsed: 21936 kB
VmallocChunk: 0 kB
Percpu: 1280 kB
CmaTotal: 327680 kB
CmaFree: 311200 kB
------ cat /boot/config.txts ------
cat: /boot/config.txts: No such file or directory
------ cat /boot/firmware/config.txt ------
# http://rptl.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
#add Following content:
dtoverlay=camera-mux-4port,cam0-ov5647,cam1-ov5647,cam2-ov5647,cam3-ov5647
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
------ libcamera-still --list-cameras ------
Available cameras
0 : ov5647 [2592x1944 10-bit GBRG] (/base/axi/pcie@120000/rp1/i2c@88000/ov5647@36)
Modes: 'SGBRG10_CSI2P' : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
------ libcamera-hello ------
[0:07:39.350217120] [2688] e[1;32m INFO e[1;37mCamera e[1;34mcamera_manager.cpp:284 e[0mlibcamera v0.2.0+120-eb00c13d
[0:07:39.357996263] [2691] e[1;32m INFO e[1;37mRPI e[1;34mpisp.cpp:695 e[0mlibpisp version v1.0.5 999da5acb4f4 17-04-2024 (14:29:29)
[0:07:39.374446340] [2691] e[1;32m INFO e[1;37mRPI e[1;34mpisp.cpp:1154 e[0mRegistered camera /base/axi/pcie@120000/rp1/i2c@88000/ov5647@36 to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_C0
Made X/EGL preview window
[0:07:39.735033104] [2688] e[1;33m WARN e[1;37mV4L2 e[1;34mv4l2_pixelformat.cpp:344 e[0mUnsupported V4L2 pixel format RPBP
Mode selection for 1296:972:12:P
SGBRG10_CSI2P,640x480/0 - Score: 3296
SGBRG10_CSI2P,1296x972/0 - Score: 1000
SGBRG10_CSI2P,1920x1080/0 - Score: 1349.67
SGBRG10_CSI2P,2592x1944/0 - Score: 1567
Stream configuration adjusted
[0:07:39.735332849] [2688] e[1;32m INFO e[1;37mCamera e[1;34mcamera.cpp:1183 e[0mconfiguring streams: (0) 1296x972-YUV420 (1) 1296x972-GBRG_PISP_COMP1
[0:07:39.735462851] [2691] e[1;32m INFO e[1;37mRPI e[1;34mpisp.cpp:1450 e[0mSensor: /base/axi/pcie@120000/rp1/i2c@88000/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected CFE format: 1296x972-PC1g
[0:07:44.481358839] [2691] e[1;33m WARN e[1;37mV4L2 e[1;34mv4l2_videodevice.cpp:2007 e[0;32m/dev/video4[16:cap]: e[0mDequeue timer of 1000000.00us has expired!
[0:07:44.481429859] [2691] e[1;31mERROR e[1;37mRPI e[1;34mpipeline_base.cpp:1334 e[0mCamera frontend has timed out!
[0:07:44.481440748] [2691] e[1;31mERROR e[1;37mRPI e[1;34mpipeline_base.cpp:1335 e[0mPlease check that your camera sensor connector is attached securely.
[0:07:44.481449359] [2691] e[1;31mERROR e[1;37mRPI e[1;34mpipeline_base.cpp:1336 e[0mAlternatively, try another cable and/or sensor.
michael@pi-ai:~ $ libcamera-still -t 0 --camera 0
[0:09:23.618626493] [2776] INFO Camera camera_manager.cpp:284 libcamera v0.2.0+120-eb00c13d
[0:09:23.626471137] [2779] INFO RPI pisp.cpp:695 libpisp version v1.0.5 999da5acb4f4 17-04-2024 (14:29:29)
[0:09:23.642511449] [2779] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@88000/ov5647@36 to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_C0
[0:09:24.015810960] [2776] WARN V4L2 v4l2_pixelformat.cpp:344 Unsupported V4L2 pixel format RPBP
[0:09:24.016130501] [2776] INFO Camera camera.cpp:1183 configuring streams: (0) 1296x972-YUV420 (1) 1296x972-GBRG_PISP_COMP1
[0:09:24.016270022] [2779] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@88000/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected CFE format: 1296x972-PC1g
[0:09:30.051784478] [2779] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video4[16:cap]: Dequeue timer of 1000000.00us has expired!
[0:09:30.051832683] [2779] ERROR RPI pipeline_base.cpp:1334 Camera frontend has timed out!
[0:09:30.051841461] [2779] ERROR RPI pipeline_base.cpp:1335 Please check that your camera sensor connector is attached securely.
[0:09:30.051848813] [2779] ERROR RPI pipeline_base.cpp:1336 Alternatively, try another cable and/or sensor.
s
